Where can I get the correct "acorn" upper control arm bumpers? I ordered a complete set of suspension bumpers from Eckler's with some other stuff. The lower front bumpers and the rears are perfect, but the upper fronts are about 1/8"-1/4" too tall.
From: Las Vegas - Just stop perpetuating myths please.
Originally Posted by SIXFOOTER
soap water is a good idea, I had a can of WD handy, push in hard and twist at the same time, like your screwing it in
Maybe i had/have a bad access to them as i reach under the upper A-arms and can't produce good verticle force from ontop. Will try the WD trick next but reluctant to use petrol products on rubber items. Hey may silicone grease will get the job done?
