Transmission Cooling System
Old Nov 4, 2006 | 07:22 PM
hayman's Avatar
hayman
Default Transmission Cooling System
Anyone run their vette without the tranny coolant system hooked up? How necessary is it?
Bill
Old Nov 4, 2006 | 08:05 PM
SIXFOOTER's Avatar
SIXFOOTER
Its a very good idea to have one, although there are way better systems than what your car came with. I am putting on a dual pass heat sync type cooler mounted to the frame under the car in the slipstream.
Old Nov 4, 2006 | 08:10 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
it is very necessary.......heat destroys trans fluid once its ruined damage results do not run the car without the trans fluid being cooled
Old Nov 4, 2006 | 08:12 PM
hayman's Avatar
hayman
Where can one get replacement pre-bent tubing for a 74 350ci 400 turbo?
Old Nov 4, 2006 | 08:17 PM
bobs77vet's Avatar
bobs77vet
perhaps the after market trans cooler companies offer a universal kit you could use?
Old Nov 4, 2006 | 08:23 PM
SIXFOOTER's Avatar
SIXFOOTER
I plan on using a braided SS hose on mine
Old Nov 4, 2006 | 08:26 PM
hayman's Avatar
hayman
That's an idea. Where can you get that on a Sunday in central PA?
Old Nov 4, 2006 | 08:30 PM
bobs77vet's Avatar
bobs77vet
do youhave speed shops where you live?
Old Nov 5, 2006 | 12:22 AM
brian76's Avatar
brian76
I spoke with alot of transmission shops here in town and all over the country, and they all told me NOT to use the radiator cooler. They said that the engine coolant flows through the rad at 180-200 degrees right next to the trans cooler in the rad, and brings up trans fluid temps dramatically. They advised to run a separate cooler all together.
Old Nov 5, 2006 | 05:53 AM
marshrat99's Avatar
marshrat99
Bill
I agree that tranny coolers are absolutely necessary. You can also get the lines from Bowtie. If you drag race or pull loads then an aux cooler is recommended. When I converted over to the BTO 2004R, part of the install was a tranny temp guage and noticed that I needed both the radiator and an aux cooler to keep the tranny in Bowtie's recommended temp range.
Old Nov 5, 2006 | 08:40 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I agree with the others that you definitely do not want to disconnect the trans cooler line as that is what helps cool your tranny. Heat is the worst enemy of auto transmissions.
Old Nov 5, 2006 | 09:16 AM
bobs77vet's Avatar
bobs77vet
what are you trying to accomplish??? if this is a stock application the original radiator set up is fine.
Old Nov 5, 2006 | 09:56 AM
hayman's Avatar
hayman
The thing is I just reinstalled my engine after a cam replacement. Got every thing back together and started the engine up to break in the cam and for some strange coincidence the tranny tube under the swing arm spang a leak. It has been about two weeks since I started the re-cam project and I thought I could cut the tubes in a good section and loop a hose between the two to break in the cam and do some driving until I can get a replacement tube assembly.
I know I should be patient.
Bill
Old Nov 5, 2006 | 10:04 AM
bobs77vet's Avatar
bobs77vet
why not use compression fittings and splice in a new section?
Old Nov 5, 2006 | 01:16 PM
chris75stingray's Avatar
chris75stingray
Bill
you can just cut the tube and put a piece of hose with two clamps on it
Old Nov 5, 2006 | 09:12 PM
kaiserbud's Avatar
kaiserbud
6'r - any pics on your cooler setup
Bob - any more details/pics on the compression fittings
Old Nov 5, 2006 | 09:36 PM
SIXFOOTER's Avatar
SIXFOOTER
Looks like this, not on there yet
Using braided lines on it and mounting it to the frame right side under pass seat, should do the trick. I never liked the idea of running tranny juice thru the radiator.
To Transmission Cooling System
Old Nov 6, 2006 | 04:45 AM
kaiserbud's Avatar
kaiserbud
SO - you are talking about mounting this parallel with the frame on the inside of the outer frame rail. Any concerns about heat to passenger ..... and any methods to protect the fins. What brand is it? Last - are you totally circumventing the radiator to cool the tranny? What degree shoudl a tranny run, what are you experiencing now and what do you expect.
Old Nov 6, 2006 | 07:22 AM
Victor's Avatar
Victor
A while back I was trying to figure out what I was going to do for an extra tranny cooler and I came accross some posts by another forum member who ran two of these. He put on in each of the holes in the crossmember where the exhaust pipe goes through. I think his name was GrandSportC3 if I'm not mistaken (but I'm not 100% certain). If you aren't running side exhaust this idea obviously wouldn't work.
Old Nov 6, 2006 | 07:42 AM
SIXFOOTER's Avatar
SIXFOOTER
Inside the frame rail yes. No significant heat transfer to the passenger since it will be in the slipstream under the car and should not generate all that much heat, not worried about the fins. No idea what brand it is and yes I am deleting the radiator cooler system with an aluminum rad with no tranny provision. The tranny should be as cool as you can get it since it dows need heat to work but generates quite a bit of it. I don't know what the operating temp will be but I expact it will be well under normal temps. If one doesn't do it I'll add on a second one.
