Friggin Composite Spring
Old Nov 6, 2006 | 09:37 PM
theandies's Avatar
theandies
Default Friggin Composite Spring
I was 99% sure I would buy a replacement steel spring when I did my rear suspension about 2 years ago but I decided to go with the composite. This is the reason I did NOT want to put a composite spring on my car.
I know, I know, steel springs can break too but my 35 year old steel spring never broke. This spring has less than 2000 miles on it and it's been installed less that two years. For anyone thinking of getting a composite spring - DON'T.
I am so pissed right now I better stop typing if I want to continue to be a member of CF.
Old Nov 6, 2006 | 09:40 PM
jd1a's Avatar
jd1a
That sucks
Old Nov 6, 2006 | 09:42 PM
JoeRags's Avatar
JoeRags
Exactly why I never got one.... sorry bro
Old Nov 6, 2006 | 10:21 PM
mandm1200's Avatar
mandm1200
Why not call the manufacture and see if they will replace it. The warranty is only something on a piece of paper. If the thing failed after 2000 miles, there is a good chance they will send one out. Offer to pay the shipping.
Old Nov 6, 2006 | 10:22 PM
SIXFOOTER's Avatar
SIXFOOTER
you sure hat thing is in there right? I have never seen one do that that was installed correctly with the pads in the right place.
Old Nov 6, 2006 | 10:23 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
That sux....
Usually stuff like this happens to me..... exactly why I have a steel spring
Old Nov 6, 2006 | 10:38 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Sorry to see your having a problem witht the spring. What brand? Is it the TRW style or the VBP ?
Chevy has been using fiberglass springs on Vettes since, I believe 84.
Must be something good about them....good luck with the warrenty.
Old Nov 6, 2006 | 10:49 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Mine's been in for 25 years without a problem. Give 'em hell!
Old Nov 6, 2006 | 11:00 PM
cherrybombc3's Avatar
cherrybombc3
I feel for you Bro, but take a deep breath and call the Supplier. But for now dont publicly dog the Supplier, as these things can happen in any manufacturing process. If it was not an install issue, probably not as there arent too many ways to install them. Give em a call.
Old Nov 6, 2006 | 11:06 PM
68/70Vette's Avatar
68/70Vette
A real question to ask is..why do these springs fail?...there has to be a real reason. I would think that the manufacturer of the spring would try to discover the real reason. There's certainly a problem when it's people like me or you have to guess the reason, when I'd suspect the manufacturer knows.
It looks like your suspension has an aftermarket strut rod differential bracket. I have one. The holes on the aftermarket bracket are drilled slightly larger than stock. The stock bracket is very snug and the bracket cannot move transversely (i.e. left and right) because the shaft of the mounting bolts are almost exactly equal to the diameter of the holes drilled in the bracket. I wonder if the larger holes in the aftermarket bracket allow the entire assembly to shift slightly left and right and stress the fiberglass spring....and cause it to break.
I've held by stock differential bracket up against the aftermarket bracket and it's obvious that the aftermarket bracket has larger holes (i.e. sloppy fit).
What I did was to buy a differential bracket that was a modified original. The ends of the original stock bracket were sawed off and rewelded lower so that the strut rods were parallel to the half axles--this parallel arrangelemt is what the aftermarket bracket is striving for. By using a stock bracket, the differential mounting holes were factory precise.
Old Nov 7, 2006 | 12:09 AM
doug_dayson's Avatar
doug_dayson
My VB&P's been on 16 years or so, still good...
Doug
Old Nov 7, 2006 | 03:07 AM
mrvette's Avatar
mrvette
Doug
VBP just over a decade now....no issues...
Old Nov 7, 2006 | 04:25 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
There have been several composite spring failures reported here over the years. I remember pics of one that really shattered.
I'll stick with steel.
Old Nov 7, 2006 | 05:52 AM
Kalway's Avatar
Kalway
Who'd you buy that spring from? If it's a VB&P I bet they'll replace it.
To date, GM has never replaced a composite leaf spring due to fatigue. Only replacements have been due to other stuff interfering with the spring. I forget where I read that, though... So don't quote me on it.
I'll still take my chances with a composite spring, though. They're sooooo much lighter than steel, and USUALLY last longer.
Old Nov 7, 2006 | 05:57 AM
3rd_Vette's Avatar
3rd_Vette
Am I the only one that can only sleep an hour at a time??? Its 3am and people are still here!
Sorry for the off topic reply
Old Nov 7, 2006 | 06:01 AM
Kalway's Avatar
Kalway
Insomnia, you can attribute it to the fact that I'm in too much pain to sleep.
Old Nov 7, 2006 | 07:57 AM
bahamasair's Avatar
bahamasair
My steel spring snapped so Im going composite this time
To Friggin Composite Spring
Old Nov 7, 2006 | 08:45 AM
greyghost79's Avatar
greyghost79
had my VBP spring on for about 3 years with no problems. sorry to hear about yours. i'd call supplier and see if they won't replace if for you.
Old Nov 7, 2006 | 08:48 AM
Jud Chapin's Avatar
Jud Chapin
Doug
Got mine at the same place!
Old Nov 7, 2006 | 08:51 AM
Edzred72's Avatar
Edzred72
Old time AO Smith composite spring here going on 5yrs. Even after circle track pounding she's still springy and spry!!!
www.imagesup.com/usr/79/72RearRe-Build_005.jpg
Eddie
