Wont Start
Old Nov 7, 2006 | 12:41 AM
swensonm's Avatar
swensonm
Default Wont Start
Fellas
Need some help. Was driving maybe a mile from the house when the car started running rough then quit. Wont start now.
Good spark at the coil. replaced the rotor cap and condenser, points have less than 1000 miles on them...no joy.
Will replace the cap tomorrow (parts stores closed). gas is not old smell fuel while attemping to start, even tried starting fluid and it did not try to fire. Drove the car yesterday no problems....Any ideas?
Mike
Mike
Old Nov 7, 2006 | 12:50 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Are you getting spark at the plugs? I've seen condensation in the cap cause this. I am assuming you had rain last night like we did so maybe drying the cap might help.
Also, leave the cap off & crank the engine. Does the rotor turn? Always the possibility the dist broke, but not likely.
Old Nov 7, 2006 | 07:54 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
As stated above, check for spark at the plugs. If okay, check for fuel output to the carb. It's got to be a problem related to one of the two. Once you find out whether it's fuel or electric, you are well on the way to isolating the problem. (Make sure you have fuel in the tank )
Old Nov 7, 2006 | 08:26 AM
swensonm's Avatar
swensonm
Default More info
I do have spark at the plugs but not sure if it is "good" enough. Rotor turns and I do have fuel.
I replaced the condenser and rotor cap no change...I will replace the distro cap after work. Just seems odd to just quit like that.
I did not feel any condensation in the cap. The car was running ok for a mile then rough then quit!
Mike
how do you tell if points are bad?
Old Nov 7, 2006 | 08:30 AM
moosie982's Avatar
moosie982
Did a float sink,, or is there trash hanging up the needle and seat, try pulling a spark plug to see if its gas fouled (WET), maybe,,,,,Peace,, Moosie
Old Nov 7, 2006 | 08:40 AM
greyghost79's Avatar
greyghost79
might try spraying some starter fluid in the carb and then see if it will start momentarily. if it does, it's probably a fuel starvation problem. if it doesn't its probably a spark problem.
Old Nov 7, 2006 | 11:54 AM
swensonm's Avatar
swensonm
Default starting fluid
Grey
I tried starting fluid last night no luck! How can you tell if points are bad?????
Mike
TTT
Old Nov 7, 2006 | 12:04 PM
Jud Chapin's Avatar
Jud Chapin
Originally Posted by swensonm
Grey
Mike
TTT
They should be flat on both sides and relatively clean. If there is build up on one side, they need to be replaced. Be sure there is no grease from the cam on them. If you don't know how old they are, replace them, the rotor, and cap.
Old Nov 10, 2006 | 09:28 AM
moosie982's Avatar
moosie982
Default Swensonm,,,,,
Any good news yet? Peace,,, Moosie
Old Nov 10, 2006 | 09:59 AM
1stC3Vette's Avatar
1stC3Vette
I would suspect something like a timing chain if you have good spark and fuel. Pull the #1 spark plug and crank the motor to top dead center, use a mirror or whateve you can to see inside the hole. If it just straight up and died on you, then something major has happened.
Good luck and keep us posted,
Dino
To Wont Start
