Tachometer, 1976
Old Nov 8, 2006 | 03:04 PM
redvette1976's Avatar
redvette1976
Default Tachometer, 1976
My tach is steady on 20. That's right, it does not work. Is the most probable cause the circut board? If so how hard is it to remove the tach? Is there a troubleshooting procedure?
Old Nov 8, 2006 | 03:33 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I purchased a new circuit board for a '75 several years ago from Zip for about $100. I don't know if they are still avaliable. Installing it is another story as the dash has to be pulled down. I don't think I'd want to do that job again. Of course there is always the possibility it is not the circuit board. I'm afraid that is all I can tell you.
Old Nov 8, 2006 | 05:04 PM
72LS1Vette's Avatar
72LS1Vette
I was told that if the motor that drives the needle is good the needle will sit around 1500 when the engine is off. Sounds like your motor may be good but the board is broken. They should be available at the major vendors. If you can't find one email me and I can point you to a shop that might have a few new boards.
Rick B.
Old Nov 8, 2006 | 07:52 PM
TJ76's Avatar
TJ76
I have a 76 also. Last year my tach quit. There is a filter inline with the dist. Located on the intake manifold behind the carburetor, it looks like a small cylinder. 1 1/2" long and about 3/4" in diameter with a wire coming from each end. One of the wires on mine came loose and tach quit. All I had to do was resolder the connection, been working ever since. Hopefully that's all it is. Good luck.
Old Nov 8, 2006 | 09:16 PM
76project's Avatar
76project
my tach was steady at 1500, never moved from when I bought it. I took my dash apart, pulled my tach and this is what I found.
It is pretty common on 76 era. The trace burns out or the diode burns out. You can buy a new board or try to fix it. You have to replace the diode and repair the trace. I had a thread from when I fixed mine but can't find it. Below is from another forum member who helped me out. Sorry but at the moment I can't find his name.
It is my understanding that 1976 was the first year that corvettes had an electronic tach, and it shows!
The protection circuitry used in the first tachs was, shall we say, "less than optimal"? But we have to remember that this was designed in probably 1974, or 1975. At that time, microprocessers were only 4 bits! Automotive electronics were primarily relays and switches. Its not until stuff started blowing up that engineers started looking into automotive transients.
The issue with the original Corvette tachs is that they have a zener diode across the 12V input. If anyone ever hooks the battery up backwards, or boosts the car with 24 volts, this part is guaranteed to blow. That wouldn't be so bad if the zener blew open, then it would be gone and you wouldn't have to worry about it. However, Zeners usualy fail short. Which means it will pop a tace on your PCB. The Blown Zener diode is indicated by the arrow in the top left corner. Test Diode with Ohm meter, place positive and negative leads as shown. This should read as high resistance.
If the diode is shorted (Less than 5 ohms), remove it. Repair trace if required.
Test circuit by applying 12V to diode pads with polarity shown. MAKE SURE THE POLARITY IS CORRECT!
Now that the zener has been removed, reverse polarity will fry the board.
A current limited supply set to 200 mA is highly recommended.
The power can also be connected to the connector tabs as shown in the bottom diagram.
The square wave is the tach signal input.
Old Nov 8, 2006 | 11:18 PM
Jud Chapin's Avatar
Jud Chapin
Check it out!
http://www.zip-products.com/Zip/prod...7F86E4FBF095F9
These used to be $100.
Old Nov 9, 2006 | 06:54 AM
redvette1976
Great info. I will check the obvious first as described and go from there. Has anyone ever converted to a mechanical drive type in there 76? Would it be any better or worse than the current configuration?
Bob
Old Nov 9, 2006 | 07:22 AM
Jud Chapin's Avatar
Jud Chapin
Bob
Sounds like major work, especially when it comes to the guage. I would suggest fixing yours unless someone here has done it with favorable results. Good luck, Bob
Jud
Old Nov 9, 2006 | 09:49 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Bob
No you want to keep the original type, not go back wards.
Reminder on the '76 tach - read the instructions on that board. Do NOT move the rheostat to center the needle! Needle should zero out, when the key is on. If/when you reassemble things do not be dismayed if you see the needle off zero with no power on it.
I replaced my board and the tach filter both at the same time. Before reassembling it, I took the tach and speedo to the local speedo shop to have them worked on.
The guy zero'd out the tach using the rheostat on the board, and true'd it up with his signal generator. Now that it's back in, the tach is wayyyy of. Yea it moves, but it reads 2K RPM high at the low end, and 3500 high at the high end.
We learned quickly that his signal generator does not provide the same signal as the HEI system. I'm ticked off at wasting all that work and having a broken tach still.
Old Nov 9, 2006 | 10:00 AM
Jud Chapin's Avatar
Jud Chapin
When I put a new board in my '75, Zip told me no adjustments were necessary. However, I talked to a spedo shop and they told me the opposite. Anyway, I let the shop set it up and it was fine after installing. And yes, they do not show zero with the ingnition off. With it on, though, w/o the engine running, it should register zero. That is what my '76 does and has done since I bought in new.
Old Nov 9, 2006 | 11:45 AM
redvette1976
Thanks all again. Will keep you posted what I find. have a great weekend. To the veterans
Old Nov 9, 2006 | 12:22 PM
SanDiegoPaul
Originally Posted by Jud Chapin
When I put a new board in my '75, Zip told me no adjustments were necessary. .
Yepperz. For some reason the '76 was different.
Old Nov 9, 2006 | 12:25 PM
Jud Chapin's Avatar
Jud Chapin
Even though it's the same board?
Old Sep 13, 2019 | 12:02 PM
vettebuyer6369's Avatar
vettebuyer6369
13 year old thread, resurrected for commercial ad.
To Tachometer, 1976
