Just giving a heads up on a problem I repaired today. I have the MSD tach drive dist with a 6a ign. For a couple of weeks I've been chasing a "ghost", miss, stutter, or when I stomp it it and the 4's kick in acted like starving. Been driving her for about 300 miles since rebuild. So I do some trouble shooting, ignition first, wires, coil,can't find anything. Check fuel system,pressure great,floats levels good, carb clean. Sitting in the garage reading over the MSD install guide, twice. Look over car and over, thinking what has changed? After three weeks, phone calls and advise, I'm in the motor compartment cleaning and notice I zip tied the ignition box coil and trigger lines together running along the firewall.
The manufacture says to keep them 5-6 inches apart, NO ****! Wow did that cause wierd issues with no patterns. Reran the wires, smokes right along....
I'm running the same distributor and box, and I ran the wires together the same way
Haven't noticed any problems, but I'm going to separate them anyway.
Thanks for the heads-up
I've been battling this for three months... five or six calls to MSD techs has been very little help!.. but i read the info again and in TECH BULLETIN # 109 under WIRING a special shielded harness is offered #8862 "that protects the trigger wire from external interference" ....installed it today and so far no....well...give it a few more days
Good idea to shield trigger wire pair & to separate twp from the others. You should also twist the pair of trigger wires ... 2-3 twists/inch. Do the same to the pair of coil wires. It works but you'll have to get an EE to explain it for you.
My car came with an MSD installed already and I noticed a bundle of wires cable tied together. My question is whats the trigger wire since I didnt do the install?
ESU
Had the same deal with my Crane HI-6. I mounted the box and coil under the passenger side dash panel on an aluminum plate with some other electronics.
Car ran fine for a couple weeks, then leaving a car show of all places, pop, crackle, pop pop. Tracked it down to the ign. box trigger wire had somehow wiggled it's way to within an inch of the coil wire...........
My car came with an MSD installed already and I noticed a bundle of wires cable tied together. My question is whats the trigger wire since I didnt do the install? ESU
The trigger pair are the two running from electronic/mag/opt DIST to MSD BOX ... the coil pair are the two running from coil to BOX.
Grounds are important also.
I had a weird pulsing interior light issue untill I tied all my electrical stuff (MSD, Fuel pump, Fans) to the same frame ground point.
So make sure your grouns are good and as close together as possible
