Gear box
I took these numbers off the side of it can anybody tell me what they mean:
WL1162
17S416329
Does this mean I have an M20 or is there an M21
many thanks Jerry
http://www.corvettemagazine.com/2005...ssion-lead.asp
Muncie was used through mid-74, then Warner thereafter.
If you have the L48 it will be the M20, the L82 could be either.
For example M20 means wide ratio 4 speed but does not tell you the manufacturer. As for this tranny: "W" is Warner, then comes the date code and I believe the last digit would be "1" for wide ratio or as is the case here "2" for close ratio on a Warner box available with L-82 for '77.
Anybody have better reference material than me that can back up the Warner ratio codes?
-Mark.
M20 = wide ratio muncie
M21 = close ratio muncie
M22 = close ratio muncie with HD gear set (rock crusher)
Then explain to me why there were still M20s and M21s through 1979 when the old Muncies were discontinued in mid 1974?
Believe me, the M does NOT stand for Muncie as some people think.
ALL of GM's transmission options begin with M, ie: M38 Turbo 350, M40 Turbo 400 even M74 on the new Allison 6-speed.
M20 just means Wide Ratio. Heck in 1978, there were 2 different Wide Ratio 4-speeds and they were both M20s!!! The L48 had a Saginaw with 2.85 low and the L82 used the Warner with the 2.64 low.
2 different trannies with the same M20 RPO and neither made by Muncie.
mr303
You have a super t10 box, its not a muncie.
So I have a super t10 box.
wfo76
M20 or M21 has nothing to do with Muncie, it just means Wide Ratio or Close Ratio 4-speed manual.
so you think it is a super t10 box made by warner and is a M20 wide ratio box.
Stingr69
Actualy, he is right about the codes. For example M20 means wide ratio 4 speed but does not tell you the manufacturer.
So is mine a close ratio box on a 1977 L48?
crash-ent
The last digit of the build date designates shift(1=1st shift, 2=2nd shift)
Hope this helps... Crash
Im not quite sure what you mean by 1st shift and 2nd shift !!
thanks for your help so far but as you can see I'm still a bit confused
but hey nothing new there then.
Ratios: 2.64, 1.75, 1.33, 1.00
You might also see an "HS" stamped or painted on the left side,
this denotes the W/R 2.64 gear set.
The 1 or 2 "shift" numbers just mean the assembly plant worker's shift,
ie: assuming 1 would be the morning shift and 2 the afternoon
17S416329 is the VIN stamping and if your car's VIN ends in 7S416329
then this is the original tranny for the car.
My source for the questonable "2" suffix meaning close ratio info was a book by Richard Prince which has been proved to be less than 100% accurate.
-Mark.
Mike
Cheers for now Jerry
