since i can finally finish up the front of the motor, i'm going to switch out the wires..... what would you recommend for a 350sbc with a mild cam and regular dist...... or should i upgrade to a better system and what do they usually run.....
thanks
b
if i can get green colored wires that would be a bonus
I bought a SB GM Performance Parts Spark Plug Wire Set Part # 12361056 for my new ZZ4 but they were incorrect and I cannot use them. They had 135 degree boots on them and I needed 90 degree to clear my headers. I paid $83 for them at Summit. They are bright red with the GM logo and are still new in the box. If you want a good deal IM me.
Have run Moroso 8MM 90* boot "Blue Max" on two engines. HEI and non HEI. They come in red or blue. High heat boots NEVER melted when close to headers. I make my own for a custom fit with never a wire problem.
Eddie
thanks
b
Taylor makes high quality wires ... and Taylor offers GREEN wires in 8mm. Please ... please warn me before you open your hood.
