Video: Knocking sound problem...
Old Nov 12, 2006 | 05:58 PM
KevsC3's Avatar
KevsC3
6th Gear
Default Video: Knocking sound problem...
Ok, after pulling the pushrods out and re-adjusting the rocker arms, it is still making a tapping sound.
I hope this video can let you experts make a better diagnose the problem. cause im out of ideas lol...
http://www.innovativegamingconcepts.com/vid/
Thanks!
Old Nov 12, 2006 | 07:24 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
One bank or both?....could it be your fuel pump rod?...
Old Nov 12, 2006 | 07:39 PM
KevsC3's Avatar
KevsC3
6th Gear
It seems like its coming from the driver side of the engine, but I can not be for sure
Old Nov 12, 2006 | 07:45 PM
TopGunn's Avatar
TopGunn
What brought this on???
It's hard to tell the tone of the sound but it's sounds pretty solid and get's louder the more throttle is applied.
I had a 396 that I put together that had a bad crank journal that made a sound similar to that. Turned out to be the piston hitting the head, hope it's not that in your case but it was a pretty deep solid sound.
Did it just start that for no reason?
Old Nov 12, 2006 | 07:54 PM
KevsC3's Avatar
KevsC3
6th Gear
It came from no where...
Wife drove it and on here way home, it started making the noise, so she pulled over and waited for me to meet her to tow the vette home, before that the car ran great no sounds or anything, had plenty of oil...
Old Nov 12, 2006 | 08:18 PM
rihwoods's Avatar
rihwoods
Hard to tell,but it could be a carbon knock...mist water down carb....keep rpm's up while doing that....I'd suspect that if noise is high in engine..
Fingers crossed..
Old Nov 12, 2006 | 08:27 PM
greyghost79's Avatar
greyghost79
sounds like a big Visa bill to me.
Old Nov 12, 2006 | 08:41 PM
hwcoop's Avatar
hwcoop
sounds like rod bearing knock to me, I think its teardown time
Old Nov 12, 2006 | 08:52 PM
G dad's Avatar
G dad
Studs pulling up...are yours pressed or screwd down. ya may have one pulling up slowly. No matter how much adjusting ya do it i'll pull & make noise
Old Nov 12, 2006 | 08:55 PM
45ACP's Avatar
45ACP
That sounds absolutely horrific.
If you can't figure out where the noise is coming from, I'm guessing you are quite new to the game. You need somebody that has been at it awhile to give it a listen/take a look at it to begin the process of putting it right.
My best guess from what I hear: a helluva rod knock.
Whatever it is, you musn't run it any more than absolutely neccessary. Components making noise like that sometimes suddenly seek daylight.
To Video: Knocking sound problem...
