Headlight ajar switch adjustment
Old Sep 21, 2001 | 10:36 PM
rdrman's Avatar
rdrman
Default Headlight ajar switch adjustment
Got my headlight covers allined ,and thanks to all that helped me :cheers: They open and closed fine now.But the micro switch is indicating that the door is ajar.,when there open/How is this ajusted?Dose it screew in or out? Hard to tell from the AIM or the Hatnes manual/ :seeya
Old Sep 26, 2001 | 07:30 PM
rdrman's Avatar
rdrman
Default Re: Headlight ajar switch adjustment (rdrman)
ttt
Old Sep 26, 2001 | 08:01 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Hey, glad to hear that you got your lights aligned....now for your other question, it sounds like the lights are not "snapping" all the way up. If that is the case, you have to adjust(lenghten)the travel of the actuator arm by unscrewing the eye bolt so that the light "snaps" up and the micro switch makes contact with the light linkage. If you lay on your back and look up through the holes in the bottom of your front lower valance, you will see the light mechanism and the micro switch and where it makes contact.
Hope this helps. :D
Later
Bruce
Old Sep 26, 2001 | 08:06 PM
rdrman's Avatar
rdrman
Default Re: Headlight ajar switch adjustment (7t2vette)
Thanks I'm going to look at it right now. :cheers:
Old Sep 26, 2001 | 08:14 PM
rdrman's Avatar
rdrman
Thats it need about 1/4 to 3/16 to go.Will adjust tommarrow. It"s great when you get a answer to a problem like this ,thats why this sight is #1
Old Sep 26, 2001 | 08:49 PM
7t2vette's Avatar
7t2vette
Glad to help you buddy.....you are right, this site ROCKS!!!!
To Headlight ajar switch adjustment
