C-3 Brakes
Old Nov 14, 2006 | 02:06 PM
jack 69's Avatar
jack 69
Default C-3 Brakes
new everything.... ss calipers, master,lines.roters and dot5 fluid... i drove up in the mountins and back 3 or 4 times in the last couple of weeks... 5k foot elevation change. coming down i lost the hardness in the brake and some of the stop! saw or read something about dot 5 and elevation change,.. had to do with the loss brakes... any thoughts on this?
thanks!
Old Nov 14, 2006 | 02:36 PM
SIXFOOTER's Avatar
SIXFOOTER
sometimes there are very tiny air bubbles in dot5 that you need to remove by boiling the fluid before putting it in. The bubbles can appear later and cause some white knuckle braking. Rebleed the brakes and you should be ok. For grins and to make sure everything is good, verify the runout on the rotors, it should be under .002". Excessive runout will cause the rotors to suck air into the caliper but not necessarily leak brake juice on your tires.
Old Nov 14, 2006 | 02:56 PM
Tom454's Avatar
Tom454
Old Nov 14, 2006 | 04:47 PM
jack 69's Avatar
jack 69
thanks!... thought i was going to spend more $$$$$$$$$!!!!....
Old Nov 14, 2006 | 06:30 PM
flynhi's Avatar
flynhi
Install orings on the caliper pistons to reduce pumping.
Old Nov 14, 2006 | 07:24 PM
JPhil's Avatar
JPhil
I've had the reverse happen: upon coming up from sea level to 5000 feet, the rear brake on my bike siezed up. Removed the master cylinder cap and burped and bled it and all was OK. It's entrained air in the fluid, I guess we could call it the bends for brakes systems. Bleed 'em out and you should be OK for good, as the teeny bubbles have now come together to make bigger bubbles which can be bled out.
John
Old Nov 14, 2006 | 09:03 PM
jack 69's Avatar
jack 69
poped the lid on the master cylinder and it was full and over full.... i'll bleed them
thanks!
To C-3 Brakes
