thermostat question
Old Nov 14, 2006 | 07:53 PM
1Z87L8's Avatar
1Z87L8
Default thermostat question
OK guys, i know how a thermostat works
and right now my car has a 195 in it.
while its apart would it be worth it to switch over to
a 180 or should i just stick with the 195?
Old Nov 14, 2006 | 08:22 PM
gerry72's Avatar
gerry72
Depends. To a point, the cooler you can run the engine, the lower the octane threshold which means that if you're "iffy" on premium then a cooler cylinder head by 15 degrees can make a difference and allow you to optimize your timing. But if your engine has a no problems at optimum timing now, then you get nothing good.
Again, up to a point, the hotter you can run the combustion chamber the better the engine will run. Cool walls tend to give HCs a place to hide by dropping out of vapor. Heat vaporizes the fuel and makes the mixture more homogeneous which makes more power.
There is also no one size fits all answer to the question. You have to try it by careful experimentation. No one can tell you one way or the other on your engine.
Old Nov 15, 2006 | 07:49 AM
1Z87L8's Avatar
1Z87L8
i guess i will stick with the 195 for now.
Old Nov 15, 2006 | 08:13 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I always go with what the factory puts in.
Old Nov 15, 2006 | 08:17 AM
PhotoVette1's Avatar
PhotoVette1
If you do go with a 180F TStat, make sure the EFE TVS is opening as well--The TVS is designed to open at 180F and if its a little off setpoint, you might be running constantly with your EFE valve engaged. I'm not sure which years have the vacuum operated EFE valve--my '77 does--but its something to watch out for.
Old Nov 15, 2006 | 09:58 AM
genuine1980's Avatar
genuine1980
The purpose of a t-stat isn't really to keep the engine cool... it is to get it up to operational temp fast... then open. Once it's open its going to run as hot or cool as the cooling system will allow. If your car is running normally above 195 with your 195 tstat... it wont matter if you put a 160 tstat, your car will get upto what it normally does only slower.
It will only make a different if your cooling system is capable of making it cooler. If your car has a 195 tstat and it runs at 195, but the cooling system is capably of keeping it at 160... then a 180 tstat will lower the temp to 180.
So the question is... with the 195 tstat does your car already run above 195?
Old Nov 15, 2006 | 10:48 AM
1Z87L8's Avatar
1Z87L8
Genuine as i said in first post i do know what the stat does
and mine at 195 runs right at 195 + or - 2 degrees
until i get it on the highway for extended speeds then it goes
to about 205 but from what i have read on the forum here that
is totally normal.
for running cooler i guess i wouldnt know for sure unless i tried the
180 to see what will happen.
it does have a new radiator and hoses already and is getting the new pump as i put it back together, not that it needs it but since im in there im swapping it out.
i was just curious if the 180 would be a good change to try.
Old Nov 15, 2006 | 11:08 AM
genuine1980
is totally normal.
Well being that your running 195 + or - 2 degrees your right that you wont know for sure unless our try. I was just commenting because many people "think" they know what a tstat does and "think" that lowering the tstat will always lower the car's running temp. So all I was trying to say is that if your car has a 195 tstat and is already normally running over 195 (which was an unknown until your last post)... putting a 180 or 160 tstat will do nothing but make it longer before the car reaches that normal temp.
Btw - I have run a 180 and I run right around 180, so I tested a 160 for giggles and the temp lowered... I still run a 180 because I've heard on this forum that a 160 is not hot enough to effectively get rid of condesation. My car also increases to around 190-200 when I drive over 90mph for a prolonged time on a hot day... Like you, I've heard this is normal.
Old Nov 16, 2006 | 01:50 PM
MartyW's Avatar
MartyW
I would go with the 180. I just switched mine to a Robert Shaw 180 and could not be happier.
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 16, 2006 | 03:10 PM
7T2Z28's Avatar
7T2Z28
180 to 185 is more ideal for a thermostat, to go cooler is generally not a good idea. They went to a 195 to improve emissions. The components are designed for fit at the specific operating temperature, and at cooler temps the fit is looser. Similarly, at higher temperatures the fit becomes tighter.
Depending on what is in your block with clearances, you will want a different operating temperature. So actually, it will depend on your engine. If it is still factory original, then go with 180 or 185.
Old Nov 16, 2006 | 03:16 PM
bence13_33's Avatar
bence13_33
As someone pointed out, a thermostat's purpose isn't really to keep your motor cool...it's to keep it from running too cold. Most engine wear occurs on a cold motor, so the thermostat's job is to get your motor to 160, 180, 195 or whatever your thermostats temperature may be quickly. The 195 is mostly used to control emissions.
As stated above it doesn't matter if you run a 160 thermostat if your motor normally operates at 190 it's going to go to 190 just a bit slower. I run a 160 with the big block but it always manages to make it to it's destination of 190 or so.
Old Nov 17, 2006 | 09:41 PM
Leclaire's Avatar
Leclaire
Default I'm confused
My 78 stock L-82 runs a little over 200 degrees. I read in Corvette Fever that it was a good idea to lower the temperature to around 180 degrees. It was recomended that by using a 160 dgr Tstat the resulting temperature for the engine would be 180 dgr. I installed the 160 dgr Tstat and now the car runs at 150 dgr. What's up with that?
Old Nov 17, 2006 | 10:51 PM
Glassbowtie77's Avatar
Glassbowtie77
Same here, Robert shaw 180 and very happy with it.
To thermostat question
