I have a '76 with a Super T10 that I'm running behind my big block with slicks and I haven't had any problems yet. I went 12.1 @ 118MPH with it. I have since rebuilt the motor and it's about 100 horsepower more and I haven't had any problems yet. People don't give the Super T10 enough credit. It's a pretty strong transmission.
i have it on my '77 with a 406ci 570hp...it's indeed a fearless device
I have one too, but not behind my 540. The "TORQUE" rating of the Super T-10, or any trans, depends on the gear ratios it has. The highest rating for the T-10 is 425 ft lbs, beyond that, you are pressing your luck. ZZ502's have been known to scatter them all over the pavement.
I have one too, and the "TORQUE" rating depends on the gear ratios it has. The highest rating is 425 ft lbs, beyond that, you are pressing your luck. 502's have been known to scatter them all over the pavement.
i've got a 530tq figure...mine is a rebuilt stock '77...about 3.000 miles and still there one piece...
actually i'm going soon to an uprated M22 4 speeds trans, so i can put the t-10 apart and save its integrity.
Had a close ratio super t10 before I converted to a tko. The close ratios are rated at 375 ft/lb of torque. I was pushing about 440 ft/lb thru it with no problems. If you go to the Richmond web site, they give the ratings for all the different ratios. I hammered mine had no problems.
