Leak
Old Nov 16, 2006 | 09:55 AM
SoCalErv's Avatar
SoCalErv
Army
Default Leak
On the drivers side rear of the block, in front of the oil filter, close to the freeze plug I have a slight leak of something which I believe to be coolant. That small area has a slight film of something. When parked a drip or two will hit the exhaust or it has blown there during a drive that smells like a plastic bag that is melting on the exhaust.
Does colloant have this distinctive smell? Is there any sending units in this area that could be the culprit?
Plan to jack her up tonight and take a closer look.
Old Nov 16, 2006 | 10:58 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You're on the right track. Get in there for a look see.
Old Nov 16, 2006 | 11:11 AM
genuine1980's Avatar
genuine1980
Coolant smells and tastes sweet... When it boils/burns it has almost that same distinctive sweet smell. Does not smell like burning plastic or rubber.
Coolant is VERY toxic, so don't go tasting it. But if you need to know, you can get a tiny dab on your finger and touch it to you tongue. But then rinse your mouth out LOL.
Old Nov 16, 2006 | 08:38 PM
SoCalErv's Avatar
SoCalErv
Army
Well it is oil around the head and block in the vicintity of the oil filter and dip stick. I can not determine at this point the exact origin of the leak.
Any suggestions?
Old Nov 16, 2006 | 08:54 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Coolant near the freeze plug is likely just that....a freeze plug leaking coolant. Poke at your wet freeze plug with a screwdriver and see if your freeze plug is solid. I had one doing what you describe and when I poked at it the screwdriver went right through as if it were made of foil so have a large catch pan handy. If it is the freeze plug it can be replaced with the block in the car but it's not a pleasant job esp if it's the plug right under the motor mount.
Old Nov 17, 2006 | 11:28 AM
SoCalErv's Avatar
SoCalErv
Army
Any tricks of the trade to identify the origin of the oil leak?
Old Nov 17, 2006 | 12:06 PM
yellovette's Avatar
yellovette
The dealerships use a dye in the oil to identify the source of the leak. It is harmless to the engine.
I have used a simpler method which is sometimes effective. I've found that using tissue paper, like a kleenex, works well for tracing small amounts. Obviously you can only use it when the vehicle is stationary. Rub suspect areas w/ the Kleenex, then check for oil on it. Repeat the procedure with a clean area of the tissue. Using rags or other material doesn't work well because small traces of oil are absorbed quickly without leaving much of a mark.
Old Nov 17, 2006 | 12:15 PM
Jud Chapin's Avatar
Jud Chapin
Try cleaning the area of all residue and then run the engine. This may allow you to pinpoint the leak. Also, when the engine is cold, run your fingers aroung the bottom of the valve cover and see if you pick up any oil.
Old Nov 17, 2006 | 02:05 PM
Paul L's Avatar
Paul L
As Yellovette noted, you can buy a fluorescent dye for the crankcase and it is not expensive ($3-4). GM has it. But you will need a black (UV) light to seek where the leak is.
Old Nov 17, 2006 | 03:23 PM
Glassbowtie77's Avatar
Glassbowtie77
If you think it's oil check your oil sending unit. It is located right near the oil filter, either the sender is leaking or it's the fitting where it goes into the block.
To Leak
