Speedo gears.
Old Nov 17, 2006 | 01:25 AM
BB72's Avatar
BB72
Default Speedo gears.
Does anybody know what colour tranny gears you use to get the correct speed reading . I have a st-10 with 3:73 gears. Thanks. Rob
Old Nov 17, 2006 | 08:08 AM
wayne_69_427's Avatar
wayne_69_427
Get out on the highway with mile markers and check the odometer you will know if you have right gear or have to make a change.
Old Nov 17, 2006 | 09:09 AM
sperkins's Avatar
sperkins
We still need to know tire size. You need to find out what color "drive" gear your tranny came with in order to match up the correct "driven" gear.
Old Nov 17, 2006 | 11:03 AM
BB72's Avatar
BB72
Default Problem
I have the gears that were in it ...before I started rebuilding it...lol. This tranny is out of another car. I'm going to try and match the stock 27 inch tire height. I'm looking at getting the 17x8 or 17x9.5 torq thrust d's. What is the tire height that you guys are using to get a good fit in the wheel well?
Old Nov 17, 2006 | 11:31 AM
sperkins's Avatar
sperkins
I'm guessing you're running 225/70/R15? It has a diameter of 27.4".
If so you can run these to acheive similar OD:
255/55/R17
255/45/R18
Both have a dia of 27.0
Here's a cool link to determine tire size:
http://www.miata.net/garage/tirecalc.html
Also, I would call these guys to figure out your speedo gear situation. They have helped me in the past.
http://www.transmissioncenter.net/sp...____va.htm#t10
To Speedo gears.
