Tach problem
Old Nov 18, 2006 | 08:20 AM
Dave Witman's Avatar
Dave Witman
Default Tach problem
I have a 79 with stock ignition with a peged out tach. With ignition on tach pegs out above 7000 then when you start car tach goes to about 3000 rpm and will read very high. It will also peg out when you touch the gas. You think its the circuit board or should I look for something else. Thanks Dave
Old Nov 18, 2006 | 08:42 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would look at the circuit board. I think it is quite easier to get to then my '76.
Old Nov 18, 2006 | 08:54 AM
Dave Witman
I was just under the inpression that the tach board was more for non working tachs which really does not make mush sence anyway.
Old Nov 18, 2006 | 09:01 AM
Jud Chapin's Avatar
Jud Chapin
You may be right. I'm suggesting it because I think it easy to get to and obviously it is getting power. If it is easy to get to, just look for burn spots on the board.
Old Nov 18, 2006 | 09:04 AM
Dave Witman
OK Thanks I will do that. Dave
Old Nov 18, 2006 | 09:10 AM
Jud Chapin's Avatar
Jud Chapin
One other thing, Dave, I put a new board in a '75 which I got from Zip. They told me no adjustments were necessary and to just install it. I later talked to a speedo shop and they said it definitely needed to be set up before installation. I don't know who is right but I did let the shop do its thing because it was such a pita to get to and I didn't want to have to pull it out again. I don't know if yours is adjustable or not. Jud
Old Nov 18, 2006 | 09:19 AM
80_vette's Avatar
80_vette
I would also look at the tach filter.If it ain't working right you won't get good signal at board.I changed both the filter and the board.
Worx perfect now
Old Nov 18, 2006 | 09:23 AM
Dave Witman
OK thanks guys I did a search before I started this thread and got a lot of info on adjustments and other problems but none were specific to my problem. Thanks
Jud Chapin's Avatar
Jud Chapin
Worx perfect now
Did you install the board without it being set up?
Old Nov 18, 2006 | 09:25 AM
Jud Chapin's Avatar
Jud Chapin
Good luck and let us know how you made out, Dave.
Old Nov 22, 2006 | 06:29 PM
Dave Witman
OK I made time today to work on the tach problem.I found the tach filter missing and the circuit board has burn marks also. I ordered both so I should be good to go. Dave
To Tach problem
