finally reassembling my 427
Old Nov 18, 2006 | 11:37 AM
dragonracer's Avatar
dragonracer
Default finally reassembling my 427
It's been a long time since I reassembled a motor so my
question is... do I use or need to use gasket sealer on the
cast iron heads.
Old Nov 18, 2006 | 12:05 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If you are talking about head gaskets, no, you do not want to put anything on them.
Old Nov 18, 2006 | 12:56 PM
dragonracer
Thnx!
Old Nov 18, 2006 | 01:06 PM
zwede's Avatar
zwede
Not so fast: what kind of gasket?
If it's a composite gasket (fel-pro blue is the most common) then you do not use a sealer. Be sure the surfaces are free of oil & grease. I like to wipe the surfaces with carb cleaner. Do NOT wipe the gasket with anything.
Copper or steel shim gaskets work better with sealers.
To finally reassembling my 427
