Top end oiling
Old Nov 22, 2006 | 06:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by Hvymtlc5
Good info...but engine oiled fine before with original cam (before the wiped one and this new one). I'm going to run it with the covers off tonight to see how bad it really is....may put the stock rockers back in.
Did you not have the valve covers off to determine low oil flow in the first place ?
If not how did you determine you had low oil flow to the top end ?
Old Nov 22, 2006 | 06:51 PM
langg's Avatar
langg
How much evidence of oil should there be?
Old Nov 22, 2006 | 06:56 PM
MotorHead's Avatar
MotorHead
At idle the oil just dribbles out, enough to oil the rocker basically. It doesn't shoot all over the place, it can under certain circumstances but normall a stock or mildly built motor will just dribble
Old Nov 24, 2006 | 09:59 AM
Durango_Boy's Avatar
Durango_Boy
I do remember hearing something a while back, that adding roller rockers does affect how much oil is allowed up the pushrods. I read, that in these instances, pull the clips out of the tops of the lifters, and remove that tiny disc that's covering the hole. Doing this will allow more oil to go up, and the rocker regulates the pressure and how much oil passes it, instead of the disc in the lifter. Anyone else heard this?
Old Nov 28, 2006 | 07:32 AM
Hvymtlc5's Avatar
Hvymtlc5
Well - took a chance and went ahead and started the motor it did take a few agonizing seconds for the oil to start flowing...but it did start flowing and both banks are oiling well. Don't understand why the big drill wouldn't prime it but all appears to be working fine now....
Old Nov 28, 2006 | 05:55 PM
Durango_Boy
There could be several reasons why, but the important thing is that you've seen oil coming from the push rods, oiling the rockers.
