Door Spring Replacement Help!!!
Old Nov 21, 2006 | 03:22 PM
redman76's Avatar
redman76
St. Jude Donor '09
Default Door Spring Replacement Help!!!
I just bought 2 replacement door springs and the install tool for my '76. Can anyone tell me the easy way to replace these or point me to a "how to"? Do they just pop out and pop in. It's a tight spot and I haven't found anything yet that's easy to do
Old Nov 21, 2006 | 03:31 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
It's not easy, that's for sure. The installation tool and a hammer to tap the spring up and down will be useful. I don't remember exactly but I think I put the top in first, pulled it down and used the tool to twist the spring, then tapped it up until it engaged the hinge.
Old Nov 21, 2006 | 03:34 PM
randyredleg's Avatar
randyredleg
Go to corvettefaq.com. Click "Interior" and there is an article labeled Door Spring Replacement".
Old Nov 21, 2006 | 03:38 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
St. Jude Donor '03
If you position everything right, including the tool, you can use the door to do the twisting. Depending on left or right door, look and see which direction you ned to twist the spring. Set the tool against the leading edge of the door and slowly pull the door toward closure. When the spring end lines up, tap it in with a hammer.
It's frustrating the first few times but is really quite easy once you get the hang of it. WARNING! Do not throw the hammer at your other vehicle if you get pissed.
Old Nov 21, 2006 | 05:07 PM
redman76's Avatar
redman76
St. Jude Donor '09
That's exactly what I needed guys. Thanks, I'll try it tonight!!!!
Old Nov 21, 2006 | 06:29 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
I took my doors off to do this. My doors' "armpits" were so disgusting I wanted to clean them up. I stripped and repainted the hinges at the same time.
Old Nov 21, 2006 | 06:33 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Another tip- put a towel or old tee shirt in the space between the door and the body at the doorsill to protect the paint when you drop the spring. I must've dropped mine a half dozen times before I learned the trick to install. Glad I used a cushion.
Old Nov 21, 2006 | 09:18 PM
1FSTZ06's Avatar
1FSTZ06
I used a bent hanger to sort of suspend the spring with one hand and then used the "tool" to tap it into the holes...then tapped it with a hammer.
I almost have to laugh because after many attempts I seriously thought this was a cruel joke someone plays on unsuspecting Corvette owners...once I looked at the opposite side to see exactly how it fits into place it made sense. Good luck, it will take a little time and patience.
Old Nov 22, 2006 | 01:24 AM
Carl914's Avatar
Carl914
I don't know how long I spent trying to do it without the hammer. I think they leave that part out in the instructions. A tiny hammer tap makes all the difference.
www.mycarframes.com
Old Nov 22, 2006 | 12:13 PM
BKbroiler's Avatar
BKbroiler
An easy way to get the old springs out is to cut through them with a Dremel type grinder.
Old Nov 22, 2006 | 02:50 PM
Augie 79's Avatar
Augie 79
I used a drum brake adjustment tool (looks like a fat bent common screwdriver) and a small hammer to install the one I did. Worked good.
Old Nov 22, 2006 | 05:26 PM
GTR1999's Avatar
GTR1999
Our 75 hinge mus tbe worn as I have installed the spring about 4 times already. Lasts for a few weeks then pops out again!
To Door Spring Replacement Help!!!
