Holley Tech Tip Needed
Old Nov 21, 2006 | 05:12 PM
Catfish4818's Avatar
Catfish4818
Default Holley Tech Tip Needed
Can anyone direct me to a link that tells me how to modify a list #6239 Holley carb on a 1972 LT-1 so that the distibutor receives full-ime, not ported, vacuum? I've heard that I need to remove the carb and with a dremel tool or somthing similar elongate a slot. Not sure if this info is correct, and if so, not sure what slot to elongate. Any and all info appreciated. Thanks in advance!
Old Nov 21, 2006 | 05:30 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
block the ported source off and connect to the intake behind the carb..
Old Nov 21, 2006 | 05:38 PM
gerry72's Avatar
gerry72
Agreed. You can't turn the ported port into a manifold vacuum port. You'd have to relocate the hole from the top of the throttle plate to the bottom. Just use a manifold vacuum tap.
To Holley Tech Tip Needed
