I am looking at a set of sb heads that were once drilled for the steam holes to go on a 400. Once these holes are drilled, can you still use the heads for a 355 or 383?
Yes you can, it would be wise to drill and tap for a small pipe plug. Then silicone around the plug when putting the heads on.. Make sure the plug is flush with the head surface. Simple.
Don't need the holes for a standard 350 block. Drill & tap plugs as mentioned above is best, or tapered aluminum plugs press fitted in has also worked. Whatever plug you use, it MUST be flush with the head mount surface.
Eddie
Wondering why anybody would want to go that route??Please explain.I'm still learning after all these years.
I was looking at a used set of Edelbrock RPM's on a famous auction site. They were used on a 400 and had the steam holes drilled. I am not building a 400, just a 355 or 383. I wanted to see if they would still work without having to fill the holes back in.
I have used lots of heads with steam holes on non 400 small blocks. Never plugged them, never had a problem. I used to build a lot of oval track motors and these guys loved to run 406's. Therefore, I always got a lot of drilled heads around the shop and used them on tons of different motors. I would slap em right on there if you get them.
