Idler arm - quick question
Old Nov 24, 2006 | 11:42 AM
UKPaul's Avatar
UKPaul
Default Idler arm - quick question
Afternoon chaps
A quick question - just in the middle of changing my steering idler arm & when i got the old one off I found a thin shim between the arm & the rubber seal/spacer/ring. None of my manuals show a shim here, is there a well known reason to fit a shim (that I don't know about), or is it just another mysterious previous owner thing?
Paul
Old Nov 24, 2006 | 03:58 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by UKPaul
Afternoon chaps
Paul
Are you talking about a metal washer, around the rubber part of the bushing? Can you post a picture of it?
Old Nov 29, 2006 | 05:06 AM
UKPaul's Avatar
UKPaul
Paul,
It's literally a thin shim placed under the seal between the idler arm & relay rod. It doesn't cup the seal (a thick rubber(?) ring), it just sits between it & the idler arm. I can't see any mention of it in any manuals so I left it out, but I'm wondering if there's some reason for fitting one?
To Idler arm - quick question
