Offset Trailing Arms
Old Nov 25, 2006 | 12:27 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Default Offset Trailing Arms
Dumb question time.
With offset TA do the wheels stay in the factory location? I know the double offsets are moved inward somewhat. Reason I ask is that I need to buy new TA anyway, so as long as my stock 79 alum wheels remain in the same physical location I thought I'd install Van Steel's offsets.
Old Nov 25, 2006 | 01:41 AM
Z-man's Avatar
Z-man
Regular offset TAs will keep the wheels in the stock location. You will be able to use your stock wheels with no problem.
I'm pretty sure Van Steel will confirm...
Old Nov 25, 2006 | 10:14 AM
ratflinger's Avatar
ratflinger
Thanks Z-man
To Offset Trailing Arms
