New Holly Need Brackets
Old Nov 25, 2006 | 10:19 PM
toupstrio's Avatar
toupstrio
Default New Holly Need Brackets
Is there a place where you can buy brackets made for a holly? I am replacing the quad with a holly and don't know what to do with the bracket that originally fot the back two bolts of the quad, it holds the passing gearand i think the accelerator. Has anyone prefabed one or anything?
Old Nov 25, 2006 | 11:20 PM
blctalon's Avatar
blctalon
Take a look here: http://www.holley.com/types/Throttle..._Bracketry.asp.
Then go look it up at a place like jegs or summit.
GL
Old Nov 25, 2006 | 11:31 PM
toupstrio's Avatar
toupstrio
GL
Old Nov 26, 2006 | 03:46 PM
Solid LT1's Avatar
Solid LT1
Chevy already has your answer. The LT-1 and other Holley equipped Vettes have the right throttle cable bracket. Try Paragon Corvette.
Old Nov 26, 2006 | 04:17 PM
redvetracr's Avatar
redvetracr
any chance you have a Paragon part number??
...redvetracr
Old Nov 26, 2006 | 04:47 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Are you trying to stay factory looking. Why not look at Lokar. They have a bracket and a throttle cable that will bolt right up and is infinitely adjustable. Several of us have this style setup.
Old Nov 27, 2006 | 10:38 AM
toupstrio's Avatar
toupstrio
I don't mind going aftermarket I just can;t figure out how to attach the passing gear to carb and make it work its like a I need another bracketr to make it kick in.
Old Nov 27, 2006 | 04:08 PM
1982CorvetteDude's Avatar
1982CorvetteDude
I have a holley bracket and the 700r4 adapter (if needed) on ebay right now.....
To New Holly Need Brackets
