Replacement SBC heads...????
But I will be using the standard FelPro head gasket, not any steel shim or anything like that.
Also I posted a new question regarding other damage I found upon removing the pistons....which was caused by the machine shop not turning the crank properly. Turns out that my mistake was going to last longer than the machine shop's mistake. Oh and gee...that machine shop is out of business....wonder why.
With that huge deck cut ... If you haven't experienced it already, and unless there's been some fancy-dancing done with intake gasket/ machining of intake ... I fully expect problems with intake leaking outside air/motor oil into ports & leaking water ports.
Maybe a shorter piston would suit better ... one that's not 1.560". With that huge deck cut, you're not dealing w/ the same thing everyone else has ... it's a bastard. Red-headed stepchild it is, but not a total loss by any measure ... it is manageable. But if you don't get a good grasp on exactly what's been done & what it means ... and take correct actions ... heartbreak & budget woes will surely escalate. Does this sting? ... maybe so pal, but I'm only trying to spur you into helping yourself do the right thing.
If you want to minimise squish on a street engine, aim for 30thou, but that means a 36 thou gasket - not common in my (limited) experience.
A bit of careful top end assembly and checking your intake fit and you're away. Good luck finding some new heads or getting yours sorted.
Mark.
I am the first to admit that I have much to learn about engine parameters.....so I am not taking any offense to your comments...I am open to learning.
I do not know how much the machine shop took off the block when he deck'ed it....he was not one for much communicating. I only found out about the 0.006" above, when I go the block home.
Yes the intake had to be cut down to seal. Also had to go to a shorter push rod to say on the valve stem. The original problem I had was high oil usage...a quart in 150 miles or so. I though it was the intake gasket not sealing in the lifer valley and was sucking oil. But found no problems with the gasket...that was when I did a leak down test and heard a problem and took one of the heads off. You know the rest of the story.
72LT1:
Yeah that 2.73 rear end really needs to go. That was my plan for next summer; send the trailing arms out to be rebuilts and take the diff out and have the gears changed out. Doubt that is going to happen now with this engine problem using all the funds up.
