Replacement SBC heads...????
Old Nov 26, 2006 | 08:47 AM
LannyL81's Avatar
LannyL81
Default Replacement SBC heads...????
Now that I have found the problem with my '81 engine (bent valves, possibly guides are shot as well)..I was thinking...instead of getting these heads fixed, what would be a nice replacement head? This is on a 2 bolt main, stock block, bored 0.030, flatop 2 valve relief floating pistons, stock intake and q-jet with the CCC still connected.
Present heads are GM 882's with 2.02/1.6 valves, valve guides, screw-in studs.
Suggestions????
LannyL81
Old Nov 26, 2006 | 09:42 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
We'll need some more info. What's your current CR? How much can you afford to spend? Things like that. You need to remember that heads are just part of the total package. Dart & World both make reasonable iron heads that might work. GMPP offers fastburn vortec heads, which are good, but you would need to change intakes.
Old Nov 26, 2006 | 09:58 AM
jackson's Avatar
jackson
Suggestions????
LannyL81
Your CR probably about 9:1 or slightly less now w/76cc heads ... If you go to any 64cc head it'll rise to 10:1 or more. Suggest you have your heads fixed or find a deal on a freshened set of OE 76cc iron.
here's a 16pc set of 2.02/1.6 stainless for $80
http://www.competitionproducts.com/p...sp?number=8440
here's a set of same valves with retainers, dropin Z28 springs, locks & seals for $130.
http://www.competitionproducts.com/p...?number=851226
Old Nov 26, 2006 | 10:04 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
a set of AFR 195 heads and a Hydraulic retro roller will wake that thing up. Will cost you about $2500 to do it complete but you will gain lots of power and still be a nice street engine. Post your trans and rear gear for cam recomendations.
Old Nov 26, 2006 | 11:23 AM
markdtn's Avatar
markdtn
What about a Vortec head swap? Lot of bang for the buck.
Old Nov 26, 2006 | 07:44 PM
LannyL81's Avatar
LannyL81
Engine was decked to a -0.006 (lousy machine shop...), current heads were shaved down to about 74cc, pistons are H631CP30's. I calculated the static CR to be about 9.8:1...if I remember correctly.
Current cam is a Comp Cams 268H grind along with 1.6 ratio roller tipped rockers.
Rear end is the stock 2.78 and this is a 4sp (super T-10) trans.
The original heads were the 624's and and of course were cracked, so I got a set of 882's with the larger valves, bronze guides, heavier springs, screw-in studs, guide plates.
Hopefully the heads are not messed up and I can just replace the intake valves that hit the pistons (my error...or rather followed wrong advice).
Was just wondering if their is a set of aftermarket heads that provide better flow for about the same as fixing the 882 heads???
Old Nov 26, 2006 | 11:14 PM
dgruenke's Avatar
dgruenke
There are plenty of aftermarket heads that provide better flow than the originals. There are also some aftermarket heads that are supposed to be stock replacement, but have a little better flow, such as the World Products S/R Torquer. Summit also has a set of stock style heads for only $649/pair (assembled). The only problem is that most aftermarket style heads come in 64cc or 72cc. If you are currently running 9.8:1 with 76cc or 74cc, this will raise your compression ratio too high for the street.
World Products makes the S/R Torquer in 76cc. They are $799/pair from Summit.
Old Nov 27, 2006 | 09:33 AM
jackson's Avatar
jackson
Are your pistons down in hole six thousandth's? ... OR ... are they above deck six thousandth's?
And ... What gasket was on there?
Old Nov 27, 2006 | 12:59 PM
LannyL81's Avatar
LannyL81
Above the deck by 0.006...not exactly zero-decked.
Just used the standard FelPro head gasket that came in the kit, nothing special. I do not remember what its thickness was now.
Old Nov 27, 2006 | 09:56 PM
a1sensei's Avatar
a1sensei
Lanny, I have an '81 with flat top hyperteuetics, headers and duals, and CCC system in place. I did a lot of planning for the engine before I rebuilt it and went with the comp XE 262 and a set of Dart Iron Eagle 180cc runner, 72 cc chamber heads. I got them from a dealer on e-bay for under $800 delivered assembled ready to bolt on. Did a little mild port/ polish work with a dremmel tool and the car is great; fast and fuel efficient. God bless, Sensei
Old Nov 28, 2006 | 10:31 AM
LannyL81's Avatar
LannyL81
Sensei,
Did you have the block zero-decked? Sure wich I could go with headers and duals....but have to pass emissions here...at least one more time next month....after that may be not.
I will check into what my Compression Ratio would be with 72cc heads...may be these will work for me as well. I almost went with the XE262 cam...but decided on the 268H instead.
Thanks for the info. Going to check out the World Heads and the Dart Iron Eagles as well...compare the price against getting my 882's fixed.
LannyL81
Old Nov 28, 2006 | 04:19 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
if your interested, i have a set of 441 heads that i was planning on using for my motor. they were punched out to 2.02/1.60 with 120# single springs. they had fresh guides, screw in studs and a 3 angle on them when i bought them. i bought them off a guy i know (pretty well) who ran them for 3-4k miles and then pulled his whole motor down to build a blown stroker motor.
since i got them, i did some mild, well not really, porting work myself (i posted a thread about two months ago with some before and after pics. if you're interested you could search for it). these are already big 76cc chamber heads so if you're happy with the way your 882s were set up, then these would be pretty comparable.
i don't think i could let them go for less than $300, but that's not significantly more than what machine work would cost you anyway.
looking for any excuse to go with some aluminum heads. let me know.
Old Nov 29, 2006 | 10:57 AM
jackson's Avatar
jackson
I will check into what my Compression Ratio would be with 72cc heads...may be these will work for me as well.LannyL81
6 or what? above or below?
You're not gonna learn much useful info about your past or future CR if you don't know how far pistons below-above deck or zero-decked?
Old Nov 29, 2006 | 01:49 PM
a1sensei's Avatar
a1sensei
No, I did not have it zero decked. God bless, Sensei
Old Dec 3, 2006 | 11:06 PM
LannyL81's Avatar
LannyL81
Sorry....thought I answered your question last week.
The pistons are above the deck by 0.006 at TDC.
Old Dec 3, 2006 | 11:08 PM
LannyL81's Avatar
LannyL81
I will keep these in mind...going to take mine to the machine shop on Thursday and see what the price is going to be. I get the new intake valves on Wed along with the new set of pistons and rings. Your price is quite reasonable.
Old Dec 4, 2006 | 08:54 AM
jackson's Avatar
jackson
LannyL81:
355" ... H631+.030 (-5cc dv) @ 0.006" above deck, 74cc chambers with an inexpensive Victor Reinz P/N 1178SGB composition gasket (0.045" x 9.8cc) will make right at 9.3:1 SCR @ good 0.039" quench.
handy accurate scr calculator at Federal Mogul site:
http://www.21cgt.com/FMWebCatalog/frmConversion4.aspx
FYI for above scr calc ... minus sign deck clearance when piston above deck ... minus sign dome volume when piston dished or flattop w/ valve relief(s).
To Replacement SBC heads...????
Old Dec 4, 2006 | 12:25 PM
LannyL81's Avatar
LannyL81
LannyL81:
I looked at my numbers again and saw that I had read 9.8 instead of 9.3 as my CR...so yep you are correct. I also saw that I did not add in the valve unshrouding that had been done to the heads. So this pushes the head back to 76cc and drops my CR a bit to about 9.1.
I used the FelPro head gasket and thought that the thickness was more like 0.020...but will check when I get another set next week.
Old Dec 5, 2006 | 09:55 AM
jackson's Avatar
jackson
If your pistons are sticking above deck 0.006" ... you'd better not use a gasket as thin as 0.020" ... that equates to 0.014" quench ... later, if not sooner, piston will slam into combustion chamber's wedge.
Old Dec 5, 2006 | 07:08 PM
Little Mouse's Avatar
Little Mouse
If you have pistons above the deck and use a .020 gasket you can kiss your heads goodby in a hurry.
