Steering column
Old Nov 26, 2006 | 12:31 PM
hånta's Avatar
hånta
Default Steering column
Hello
I am in a center of a restauration of my car,an now have a problem with my steering column.I dont now how to separate the outer part of the column(the engine side,not on the steering wheel side.Why i wont to separate it is because i want to sand blast it an paint it.Is it some one that have a good picture soo i can see for my self how it is.I am from Sweden and i am not that good at english so if it is some one who can have an picture, i would be very happy.I have been asking here in the Swedish forum but is sems that nobody now how to do.
Regards
Lars from Sweden stingray69.hoglund@hotmail.com or hoglund.lars@gmail.com
Old Nov 26, 2006 | 02:04 PM
Duke94's Avatar
Duke94
Check out these papers. You'll find the answers here.
http://jimshea.corvettefaq.com/?page_id=4
Old Nov 26, 2006 | 04:00 PM
Jim Shea's Avatar
Jim Shea
It is always very helpful to indicate what year Corvette and what type of steering column that you have. I now see from your hotmail address that it is probably a 1969. From looking closely at your photograph of the lower end of the steering column, I can see a spring that loads the lever and shift tube. So the column must be a standard (non-adjustable) one.
My information indicates that there should be a clamp with a nut and bolt on the steering shaft just outside of the lower bearing shown in your photograph. The clamp was only used in 1969. I do not know why it was required just that one year and not the others. The rest of the lower end parts were the same in the following years. But in either case, your column does not have the clamp.
This is a link to a blowup of the entire steering column.
http://jimshea.corvettefaq.com/wp-co...9-76Blowup.doc
This is a link to a better picture of the lower end of the standard steering column.
http://jimshea.corvettefaq.com/wp-co...InstrPage2.doc
To disassemble the lower end parts, you should start by removing the Retaining Clip #60. Then the Retainer #59, the Adapter #57 and Bearing Assembly #58, and the Shift Tube Return Spring #56 should slide out of the Steering Column Jacket #42.
You will find that the Shift Tube Assy #48 will have to remain in the Steering Column Jacket. You will not be able to remove it. The Shift Tube Assy is a press fit to what is called the Gear Shift Lever Bowl #39 at the upper end. There is not a good way to undo the press fit without a special tool.
Just remember, additional help is only a computer click away.
Good luck,
Jim
Old Nov 26, 2006 | 05:23 PM
hånta's Avatar
hånta
Thank you
Now have i finally got it into peaces .
So now can i go further.
Thanks one`s again .
If you are intrested to look how it`s going for me,take a look here:
Part 1 http://s6.photobucket.com/albums/y208/larshoglund/
Part 2 http://s60.photobucket.com/albums/h25/larshoglund2/
Regards
Lars from Sweden
Old Nov 26, 2006 | 07:29 PM
Jim Shea's Avatar
Jim Shea
Great pictures. I have a lot of respect for you guys that tackle a complete rebuild from overseas! If we can help just post right here.
Jim
Old Nov 27, 2006 | 01:24 AM
hånta's Avatar
hånta
Thanks Jim Shea
That feels great that i am welcome to post some questions here,to bad that i am so bad to express my self.But i understand better .
Thanks one`s again.
Lars
Old Nov 27, 2006 | 01:30 AM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
Awesome pics...gorgeous car.
Old Nov 27, 2006 | 10:22 AM
hånta's Avatar
hånta
Thanks DVNTST8
Lars
To Steering column
