Muncie Trans Info
Old Nov 27, 2006 | 09:55 AM
CoolShark's Avatar
CoolShark
The splines changed in 1970, I believe, so changing input and output shafts or the clutch, etc. would be needed if you got one of those.
Old Nov 27, 2006 | 09:56 AM
international blue's Avatar
international blue
http://www.5speeds.com/muncie.htm
This site has everything. If you are considering new however, why not consider a 6 speed upgrade for milage and top speed?
Old Nov 27, 2006 | 10:04 AM
RNR75's Avatar
RNR75
Default Muncie Trans
So According To Which Spline Count I Get I Would Change The Clutch On The Input And The Driveshaft Yoke On The Output?
Old Nov 27, 2006 | 10:21 AM
RNR75's Avatar
RNR75
Default Muncie Trans Info
The Muncie M-20 That Came Out Of My 75 Needs To Be Replaced,,, Do I Need A Year Specific Replacement Or Can It Be Any M-20 Including Late 60's.
Thanks Rich
Old Nov 27, 2006 | 12:48 PM
Kid Vette's Avatar
Kid Vette
Thanks Rich
Can't be rebuilt?
Old Nov 27, 2006 | 01:38 PM
Gordonm's Avatar
Gordonm
Why not rebuild it? Or do you have an older Muncie already and want to replace it with the older one. Yes the clucth disc and output shaft will be different.
Old Nov 27, 2006 | 02:24 PM
wfo76's Avatar
wfo76
Thanks Rich
The factory manual trannies used in 75 were Warners not Muncies so check to make sure what you've actually got
Old Nov 28, 2006 | 02:33 PM
RNR75's Avatar
RNR75
The Trans Is Original And It Is A M-20, The Trans Was Under Water And The Gears Are Pitted ,,, It Would Be Expensiv3e To Completely Rebuild But I Will If I Have To. I Was Just Looking For Options.
Old Nov 28, 2006 | 03:10 PM
redvetracr's Avatar
redvetracr
It may be listed as an M-20 but as posted above the Borg Warner super T-10 is what came as original equipment...Summitt and Jegs both sell brand new replacements.
...redvetracr
Old Nov 28, 2006 | 08:23 PM
wfo76's Avatar
wfo76
Exactly. RNR75, just so we're clear, M20 is just the GM's RPO code for "Wide Ratio Manual Transmission". The "M" in M20 has nothing whatsoever to do with Muncie. Your tranny is a Warner T-10 Wide Ratio with a 2.64 low gear.
Old Nov 29, 2006 | 09:16 AM
stingr69's Avatar
stingr69
Thanks Rich
Rich,
What ever tranny was in there before - you will prefer to have the same design go back in. If you get a different one you may need to change some or all of the following: shifter mounting bracket, linkage, clutch disk, ouput yoke, or even the driveshaft. It just depends on the year model and manufacturer of the replacement tranny. IMHO it is most economical to replace the one you have with an exact match OR just rebuild the one that came out, in that order.
Upgrades are always in fashion here too but they will cost more to complete when you add in the cost for all the little bits that you will need.
-Mark.
Old Nov 30, 2006 | 07:37 AM
RNR75's Avatar
RNR75
Thanks Guys,,, I Am In The Process Of Trying To Locate A Decent Muncie M-20 To Either Rebuild Mine Or To Replace It. I Appreciate The Help.
Old Nov 30, 2006 | 12:23 PM
5speeds's Avatar
5speeds
I've seen some early 75 cars come with Muncies as well as ST10's.... People think that as soon as the production year changes that GM would just flag all the Muncies, but them away and start with another transmission. This is not the case.
Paul
To Muncie Trans Info
