HELP ON 327/350 eNGINE
I'd personally use addatives and run the best gas you can. Expensive, yes, but it is a Vette and nothing is quite like a high compression motor!!
I have a 327/350 in my '66 and absolutely love it. I wouldn't change a thing. Very few complaints of detonation with these motors over on the C2 forum. I would think that when you are done with your resto, it would be a a little more desireable car with the engine rebuilt to original specs, also. Just my .02.
Rich
331 CI, pump-friendly 9.5:1 CR
K&N 14"x4" air filter, Corvette drop base and lid
Holley 600 dp, choke horn milled, polished
1/2" Aluminum open spacer port matched to manifold, exterior polished
Edelbrock Performer RPM, port matched, exterior polished with all extraneous castings and lettering removed
Homemade lifter valley splash shield to keep hot oil off manifold bottom
Camel hump 1.94/1.50 heads hogged out to 2.02/1.60, pocket ported, port matched, pump-friendly hardened seats, 3-angle valve job
Comp Cams 1.52:1 roller-tip rockers
Crane Cam Vintage Muscle 327/350 hp cam, 222 degrees @ 0.05, 0.447" lift (with 1.50 rockers)
Doug Thorley headers, dechromed and ceramic-coated
2.5" mandral-bent exhaust (including tips), 2" cross-over just before rear axle
DynoMax stainless Ultra Flow mufflers
Mallory Hyfire IV CD ignition box triggered off Accel points
Mallory high voltage chrome coil
Mallory spiral-wound coil wire
Mallory solid copper plug wires, ends soldered to wires
Champion plugs
37 degrees total ignition advance (now 34 degrees per Lars tune-up)
Carter high volume fuel pump
Melling high volume oil pump
Open breathers
Polished aluminum high flow water pump
Flex fan with polished aluminum spacer
Polished aluminum one-wire 100 amp alternator
Muncie M-20 CR 4-speed (now Keisler TKO600 5-Speed)
Hurst shifter (Now Keisler With Hurst Tower)
3.70:1 positraction
225/60/15 Firestone Firehawk SZ50s on 7”-wide Western 30-spoke Turbine Wheels
Engine has never been professionally tuned up. Car did 293 ft-lb and 293 hp @ 5,500 rpm on the chassis dyno. Engine pulls to 6,200 rpm and does over 200 ft-lb from 1,900 rpm. This was prior to some clean-up work around the junction of the carburetor and base of the air cleaner that smooths the flow through this area and a Lars tune-up and should be good for a few ponies. Car has run 107 mph in the high 13's (old, bad tires) at the quarter. Car is extremely streetable and could probably even run 87 octane if it had to. (I can't get the engine to ping no matter how far I advance the ignition.)
The secret to power is in the attention to details!
