'82' Heater problems / questions
Old Nov 28, 2006 | 01:03 PM
Ivan_the_Red's Avatar
Ivan_the_Red
Default '82' Heater problems / questions
Greetings,
I purchased an 82 vette earlier this spring and tried to use the heater the other day, and to my surprise...... the heater blew only cold air. I think this car has some kind of vacuum controlled water shut-off valve, but I dont know exactly how it works. Any advise on how this thing works would be appreciated and is there anything else I should check in order to get this thing working again.
Old Nov 28, 2006 | 01:29 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
When the heater is running, do you have the ability to select the defrost vents, dash vents and floor vent? If not, the system isn't getting vacuum. If the vent selections work, your problem is after the heater controls and is probably the shutoff valve. Check to see if there is vacuum present at the water shutoff valve. It is located in front of the firewall where the heater hoses run to and from the heater core. Up higher in the passenger side of the firewall is a grommet with three small vacuum hoses. Those are for the heater controls. One is the source vacuum, one runs down to the switch and I cannot remember what the third does off the top of my head.
Old Nov 28, 2006 | 01:37 PM
jdp6000's Avatar
jdp6000
There is also a door in the heater core box that closes off the hot side. Easy to find. There is a cable (looks like one you would find on the brake of a bicycle) going from the switch to the box. Easiest way to examine is by removing the glove box you will see the cable attaching to a lever on the core box. Try moving the lever on the heater switch while you watch the lever....should move.You can also try moving the lever on the core box by hand and seeing if it makes a difference.
Jim
Old Nov 28, 2006 | 01:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...probably the shutoff valve...
I'd be willing to bet the shutoff valve is stuck closed.
Old Nov 28, 2006 | 02:04 PM
Ivan_the_Red
Thanks,
When I was in the car I did hear the 'switching' of the mechanisms, for example the defrost air came out by the windshield, the heater blew air both down towards my feet as well as my face, so I do believe the vacuum switching is o.k. .I do know that there is vacuum availabe at the switch but I dont hear any leaking from the switch housing. Is there any way to check that valve while its on the car. And I will crawl under just to see if the 'door' is functioning properly
Old Nov 28, 2006 | 02:24 PM
Ak. Mal's Avatar
Ak. Mal
The temp door is inside the air box. If you remove the liner of your glove box you can see the cable mentioned earlier at its endpoint on the top of the air box. I have my dash disassembled if you need pics.
Old Nov 28, 2006 | 02:29 PM
Ivan_the_Red
Thanks AK,
I'll tear the glove box liner out and check it out. Dont spend your time taking photos yet but thats really cool of you to offer. I'll keep you posted.
Thanks Jeff
Old Nov 28, 2006 | 11:19 PM
jdp6000's Avatar
jdp6000
Originally Posted by Ivan_the_Red
Thanks,
We talking about to different functions. The steel cable is on the hot to cold slider.
Jim
To '82' Heater problems / questions
