Help
Old Nov 28, 2006 | 02:32 PM
1981 corvette's Avatar
1981 corvette
Default Help
With my key out of the igniton, and steering wheel locked on my automatic 1981; I can still move the shifter thru the gears. Any idea what would allow this?
Old Nov 28, 2006 | 11:32 PM
Engage's Avatar
Engage
Default It's normal!
I went through the same thing a few months back!
The 1981 can be shifted with the wheel locked and keys out.
Barry
Old Nov 29, 2006 | 09:50 AM
UKPaul's Avatar
UKPaul
Currently got the console apart on my '81 (to adjust the starter safety lockout switch thing) & there's nothing there to stop the shifter from being moved if the key is out, etc. Think that may have been some sort of anti-theft thing on earlier models & was considered redundant with the factory alarm fitted. That's just a guess
Old Nov 29, 2006 | 10:16 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Barry
Hmm i thought there was some kind of interlock cable runing from the ingnition switch to the tranny on those later sharks......
oh well
Old Nov 29, 2006 | 10:50 AM
UKPaul's Avatar
UKPaul
From reading the manuals, so did I, but I haven't seen anything in place to stop the shifter from being moved. It's a pity that I didn't see this post yesterday as I could have taken a picture of it, but I've now got the cover balanced roughly in place with all the electrics, vac pipes, cables, etc, hooked up & really, really don't want to take it all off again (as well as all the stock wiring, mine also has an alarm system fitted under the console - can anybody say "Bird's nest"?!!).
Old Nov 29, 2006 | 11:37 AM
1981 corvette
I don't think anything would lock the shifter in the console area. On earlier models a cable from the steering wheel colum to the transmission locks the shifter.
The problem is, if you leave your car in gear, remove the key, your car could roll down the road, and that's what almost happen to me.
Old Nov 29, 2006 | 12:42 PM
MN81C3's Avatar
MN81C3
I have noticed the same thing on my 81. On one hand it makes it easier to push it back and forth when working on it. On the other hand I try to remember to use the e-brake.
Old Nov 29, 2006 | 03:24 PM
1981 corvette
Do all 81's work this way?
Old Nov 29, 2006 | 06:15 PM
1981 corvette
oh well
Do all 1981's work in this way? Maybe something in the transmission that should lock the shifter.
Old Nov 29, 2006 | 06:36 PM
es's Avatar
es
Just went and checked my '81 and durn, it DOES come out of park without the key in!!! I had never even thought of trying it before, just always turned the key when I wanted to move the shifter. Moving the car around in the garage will be alot easier now
Old Nov 29, 2006 | 06:52 PM
Kalway's Avatar
Kalway
I always stop, put it in park, then turn the key off. Why does it need to lock anyways? I always thought was handy that it didn't lock.
Old Nov 29, 2006 | 09:57 PM
1981 corvette
1. Sure would make it a bit easier to steal. Shift in to neutral and up a ramp, would not have to steer.
2. Since the shifter is not lock, a child could clime in to the car and move the shifter and next thing you know your car is headed down the road.
3. My 81 idles fast, so I like to turn the car off in gear.
If any other 81 owner would check this and let us know if the shifter will go in to gear with out the key turned.
Thanks, Hans
Old Nov 29, 2006 | 10:51 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Well, I can tell you that 78s and 79s don't have any shifter lockout, either for 4speed or automatic.
I remember my 69 GTO with 4speed. Linkage from the transmission connected to the steering column. When you put it in reverse a collar on the column inside the car turned. Without that collar turning you couldn't lock and remove the key.
Old Nov 30, 2006 | 01:52 AM
Bangkok Dean's Avatar
Bangkok Dean
Over here people park in front or behind parked cars so you leave the car in neutral so people can move the car out of the way to get out. Now of cause I don't park the Vette in these kind of parking areas but I would guess in its day it was. BTW the 4 speed don't lock when the key is removed. You do have to depress the clutch to start it(a good thing)
Old Dec 1, 2006 | 10:09 PM
Tim81's Avatar
Tim81
I have a 81 and after reading this post I gave it a try and sure enough the shifter does not lock. I recently had the console apart and don't remember seeing any type of cable or locking device. Does anyone know if the anti-theft was standard on 81's?
Old Dec 2, 2006 | 01:08 AM
Kalway's Avatar
Kalway
Sure was standard.
Old Dec 2, 2006 | 09:32 AM
Tim81's Avatar
Tim81
Great, I guess thats another area I need to start reading about. I don't think mine is working.
To Help
Old Dec 2, 2006 | 01:41 PM
3rd_Vette's Avatar
3rd_Vette
My 1980 has NEVER locked since new
Old Dec 2, 2006 | 02:36 PM
Kalway's Avatar
Kalway
Mine used to. Then it slowly started turning craptastic and now doesn't work. It used to just randomly go off. It was hilarious... for the neighbors.
Old Dec 2, 2006 | 08:35 PM
Tim81's Avatar
Tim81
Maybe I'll just pretend that it was never there..
