Door bushings
Old Sep 24, 2001 | 08:39 PM
mike79's Avatar
mike79
Default Door bushings
Has anyone had any experience in changing the bushings in the door hinges in a 79. I cannot get the top hinge pin past the curve or the top of the door. Is it necessary to remove the hinge
Old Sep 24, 2001 | 10:32 PM
wombvette's Avatar
wombvette
Default Re: Door bushings (mike79)
You can unbolt the hindge inside the door and slide it out to clear.
Old Sep 24, 2001 | 10:45 PM
CF6873's Avatar
CF6873
Mike; The top pin usually comes very close to the fender but it shouldn't be close to the door. If it is close to clearing it but not quite, take a die grinder or a file and remove one side of the head on the pin. This may let it clear the fender. Of course you will need to do the same to the new pin. Good Luck, Craig :chevy
Old Sep 24, 2001 | 10:53 PM
mike79's Avatar
mike79
Thank for the suggestions. I'll try again this weekend and let you know what works.
To Door bushings
