Straight vs Angle Plug Heads
Old Nov 29, 2006 | 09:40 PM
dinodon51's Avatar
dinodon51
Default Straight vs Angle Plug Heads
Can someone give me a quick synopsis on the advantages and disadvantages of the two types of heads? Aren't the factory small block heads "straight" plugs? I am getting a set of aluminum heads with 2.02 x 1.60 valves, 185 cc runners and will make around 10 to 1 compression if that helps. I have had ugly (and painful) experiences with headers on street cars in the past so will be keeping the stock exhaust manifold.
Thanks.
Old Nov 29, 2006 | 10:28 PM
greyghost79's Avatar
greyghost79
i have aluminum heads with angled plugs with headers on my 79 L82. if they weren't angled i'd never be able to get standard plugs in due to headers (might be able to use shorty plugs).
Old Nov 30, 2006 | 12:16 AM
Little Mouse's Avatar
Little Mouse
Yrs ago when the norm was to make good compression with big dome
pistons (12.5/13.0 race engines) they found by cutting a notch in the
dome of the piston and angling the plug they could get back some of
the good burn across the cylinder that a flat top allows. Today with
so many heads availible with small chambers, 12 to 18 degree valve
angles they can build very high compression with little or no dome on
the piston, getting rid of the big domes on pistons made them lighter
for high rpm engines. Angle plugs on a flat or dished piston street
engine, no real advantage.
Old Nov 30, 2006 | 12:36 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have found the only thing angle plug heads do over straight plug heads is angle one or two plugs directly into primary pipes so you have to ding them or, as I had to do on my Hookers, cut a tube and weld a piece in to lengthen it so it would clear the plug
Old Nov 30, 2006 | 07:01 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Supposedly angle plug heads get the spark plug into a more ideal location for the fuller combustion.
Old Nov 30, 2006 | 09:03 AM
stingr69's Avatar
stingr69
Angle plugs were used on performance replacement heads to reduce detonation tendancies. The plugs are angled closer to the exhaust valves. I do not run them as they seem to cause more problems and issues than they solve when it comes to fitting the other parts around them.
-Mark.
Old Nov 30, 2006 | 10:11 AM
kevinator80's Avatar
kevinator80
I don't think the angle plugs give any performance advantage. I run angled plugs, headers and standard length spark plugs with no problems. With any change you have to do your homework. After I bought the heads, I searched for a header that specifically said "use with angle plugs". You can't buy parts and then hope they fit. Thats when the problems show up.
Old Nov 30, 2006 | 12:24 PM
Solid LT1's Avatar
Solid LT1
Chevy first came out with angle plug SB heads in about 1972. These heads were #492 castings and only thing done was relocation of spark plug to cylinder heads. Design change was for high dome, high RPM motors. All the aftermarket heads with straight plugs have relocated plugs to top of combustion chamber so only advantage of angle plugs would be if you were building 14:1 compression engine with BIG domes on pistons and modern theory say to reduce chamber volume and run as little of a dome as possible. HP effect is very slight, maybe 8-12HP at most on angle pugs over straight plugs and that is with a BIG dome on the piston.
Old Nov 30, 2006 | 01:01 PM
S489's Avatar
S489
i have a set of the 492 on a '70 350-370hp engine now, and it seems like i recall that they were only available through GM parts beginning in '71. a lot of folks put them on their '70 350-370hp vettes and camaros in '71. that's my recollection anyway . . . i recall the 10 hp claim using the 11:1 factory pistons back in the day. no idea what was reality. i don't think most folks can feel 10 hp in the seat of the pants
MotorHead's Avatar
MotorHead
The selection of headers with over 1 5/8 " primaries that fit C3's is limited....to 1, so not alot of homework is involved here because there are no 1 3/4" headers made to fit angle plug heads
Also I run raised exhaust port heads so no off the shelf header that states it will fit angle plug head is guaranteed to fit.
Oh and just one more thing came to mind, the angles on the spark plugs can be dramatically different from one head to another, take a look at two different manufacturers heads you willl see what I mean.
Old Nov 30, 2006 | 01:38 PM
dinodon51's Avatar
dinodon51
Thanks to all of you. I think I'll remain "straight."
Old Nov 30, 2006 | 02:17 PM
kevinator80
I bought 1 5/8". Only one, that explains why they were hard to find, huh?
Dynomax ceramic, vendor's add stated "angle or straight plugs"
Old Nov 30, 2006 | 03:56 PM
75 Hot One's Avatar
75 Hot One
One of the car mags did a comparison dyno test a few years ago and, as I remember, there was no significant benefit to go to angle plugs.
Old Nov 30, 2006 | 06:15 PM
dgruenke's Avatar
dgruenke
Will an angle plug head work with the ramhorn manifolds? I am planning on getting headers, but will probably do the break-in with the manifolds.
To Straight vs Angle Plug Heads
