photo test
Old Nov 30, 2006 | 12:45 PM
73383's Avatar
73383
Default roller cam dyno problem
I recently changed to a roller and larger cam. My first cam was a:
Camshaft Specification Table
Part Number 12-212-2
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS 280H-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.48 0.48
Duration At 0.006 Tappet Lift 280 280
Valve Timing At 0.006
Open Close
Intake 34 66
Exhaust 74 26
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 230 230
Lobe Lift 0.32 0.32
Lobe Separation 110
Recommended Valve Springs 981-16
Second and roller cam was as fallows
Camshaft Specification Card BACK TO LIST
Part Number: 119661 Grind Number: HR-230/359-2S-12.90 IG
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1957 1987 CHEVROLET 8 FAIR IDLE, PERFORMANCE USAGE, GOOD MID-RANGE TORQUE AND HP, 3600-4400 CRUISE RPM, 10.0 TO 11.5 COMPRESSION RATIO ADVISED, .900" BASE CIRCLE FOR LONG STROKE CLEARANCE. BASIC RPM 3000-6500
Engine Size Configuration
262-400 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 359 @Valve 539 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 372 @Valve 558
Rocker Arm Ratio 1.50
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 35.0 BTDC 77.0 ABDC 292 °
Exhaust 83.0 BBDC 37.0 ATDC 300 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99838
Loads Closed 112 LBS @ 1.650 or 1 21/32
Open 327 LBS @ 1.120
Recommended RPM range with matching components
Minimum RPM 2600
Maximum RPM 6600
Valve Float 7000
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 8.0 BTDC 42.0 ABDC 107 230 °
Exhaust 56.0 BBDC 2.0 ATDC 117 238 °
Remarks:
The blue run was with my old cam, the red with the roller. I lost over 40hp on this cam change. Any thoughts on why. The car runs good, I have put over 5000 miles on the roller. I did notice a large loss in throttle response and gas mileage went from 19mpg to 15mpg.
Any ideas will be appreaciated
Dennis
