Brake Problems
Old Nov 30, 2006 | 05:09 PM
toddz1217's Avatar
toddz1217
Default Brake Problems
I have a question on possible brake problem.
When I am driving at say 40mph and hit the brakes hard, the car pulls to the right. I don't hear a noise it just pulls to the right.
Any thoughts.
Old Nov 30, 2006 | 05:14 PM
Durango_Boy's Avatar
Durango_Boy
Any thoughts.
Does the car itself pull to the right...or does the wheel move to the right with it?
If the wheel pulls to the right along with the car, then you have a braking issue. If ONLY the car pulls it may just be an alignment issue.
Old Nov 30, 2006 | 05:19 PM
Glassbowtie77's Avatar
Glassbowtie77
Driver's side caliper is not working properly. Either it's bad or you need to bleed your brakes. Another possibility is a bad rotor on the D/S or a leaking caliper or brake line.
Old Nov 30, 2006 | 05:33 PM
toddz1217's Avatar
toddz1217
Default Reply
If I remeber correctly the steering wheel goes with the pull.
Old Nov 30, 2006 | 09:05 PM
Glassbowtie77
Does it only pull to the right only when you step on the brakes? If so that's because your passenger side front brakes are working and the driver's side are not. If it pulls to the right even while your driving then it's probably an alignmment issue like Durango_Boy said.
Old Nov 30, 2006 | 09:22 PM
1stC3Vette's Avatar
1stC3Vette
Mine did the exact same thing when I first test drove it. The left front caliper was frozen and not grabbing the rotor. Once it worked itself free, the pulling to the right stopped.
Also, look at the inside of the left side tires and see if you notice any brake fluid leaking down the tire.
Good luck,
Dino
Old Nov 30, 2006 | 10:18 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Yep, a bad caliper on the left side...
Old Dec 1, 2006 | 04:39 PM
toddz1217's Avatar
toddz1217
Default How do you fix it
could it be a clogged line? or do I just swap out the caliper.
Old Dec 5, 2006 | 03:17 PM
toddz1217's Avatar
toddz1217
Default Problem solved
Did a brake job on the front this past saturday. Everything went well, and even bled them via Gravity with no Problem.
Thanks to Tracdogg he is the master.
Old Dec 5, 2006 | 05:13 PM
WRC7732's Avatar
WRC7732
congrats.
To Brake Problems
