question about back space...
facts: i have 8 x 15 minilites front and rear, 4'' back space all round, tires 255/60/15 front (it's well within and dont touch anywhere) and 275/60/15 rear just slightly (i'd say half inch) over the edge and dont touch anywhere either.
i have offset vansteel TA.
question: what wheel back space front and rear i will need to be withing the stock edge if i get 9 x 15 (with 265/50/15 tires) front and 10 x 15 rear (with 295/50/15 tires) ?
my thoughts: front 4.5'' and rear 5''.
what's your opinions
I dont have stock fenders...
Be careful of the section width of wider tires and more then 4" of back space...
You;ll need to move the Ebrake bracket to the top and prolly use a shorter rear spring.
Seeing how you use your car and keep in mind with 15" rubber you get a lot of sidewall deflection in hard cornering.
15x11x4 and 325/50VR15 with STOCK trailing arms. I had to move the Ebrake bracket and shorten the spring to get it to fit safely...
15x10x3 with 1.75 spacers and stock spring/Ebrake with 295/50TR15...
more positive back space means you pull the rim inside isnt it?
i've got a shorter spring now and offset TA's.
i'll get goodyear eagles and have already hoosiers dot sport tires, not yet fix though
what kind of tires are you using??
3'' backspace won't pull the rim out compared with 4 or 5''?
i think i wont be able to avoid at least 2'' flares, i'll use 4'' back space without spacers and 10x15 wheels rear with 295/50, think will do safely.
front same back space with 9x15 and 265/50 or similar...
Nitto 555R 325/50VR15 (28" tall) in the rear and 275/50VR15 (26" tall) in the front. Sticky !!
Hope this helps.
BS
