radiator installation problem help!
Old Dec 1, 2006 | 05:17 PM
gregc3's Avatar
gregc3
Default radiator installation problem help!
I have a 19698 427 that i am trying to get a reproduction radiator in. having trouble finding a way to get it in past the fan shroud. any good tips????
Old Dec 1, 2006 | 06:00 PM
loflite's Avatar
loflite
I did the radiator in my '76 which has a more convoluted shroud than the '68 I believe. I assume you have the hood off. I pulled the shroud out, then put the radiator in it's bracket. I removed the upper radiator support bracket bolts and pivoted the radiator as far forward as possible. Then after much swearing and wiggling around I got the shroud back in. It was not a fun job. Others might have a better solution. good luck
Old Dec 1, 2006 | 06:31 PM
Duke94's Avatar
Duke94
Remove the bolts holding the core support and move as far forward as possible (hood off too). Then install the rad and shroud together. It's a PITA but can be done using some choice words. I've done this w/o moving the core support also. The trick seems to be installing the rad and shroud together. Takes two people.
Old Dec 2, 2006 | 07:03 AM
bigvette1's Avatar
bigvette1
This is sound advice. You have to loosen the core support and push it forward the max. Hood off, 2 people, gloves on, cardboard on the radiator coils and work.
Old Dec 2, 2006 | 08:39 AM
marshrat99's Avatar
marshrat99
Replacing my 79's rad was a PITA. I agree that you'll need to remove the hood and unbolt the radiator supports and move the old rad forward to get the shroud out. Definitely worth having a second pair of hands involved and a six pack of
Old Dec 2, 2006 | 09:07 AM
gregc3's Avatar
gregc3
Default radiator
thanks for all your advice. i will give it a try today
Old Dec 2, 2006 | 02:26 PM
71rdster's Avatar
71rdster
It might be easier to pull the shroud, and put the radiator and shroud in together.
my.02
Orville
To radiator installation problem help!
