nothing lines up...wtf
Old Dec 9, 2006 | 05:12 PM
onaqwst's Avatar
onaqwst
Default nothing lines up...wtf
i have new zoop billet brackets and a 1" cog drive setup on my sbc.... well, the crank pulley and alt pully are lined up.... but the wp pulley is 3/4" off and the powersteering pump wont fit in the area with the new bracket/pulley...... i'm really pissed now...... did i do something wrong again or is it that i cant run ps with the brackets i have...... do i have to notch the frame/bracket?...... and not sure why the wp pulley is so far off ........
any suggestions
b
Old Dec 9, 2006 | 05:35 PM
77 vette's Avatar
77 vette
Looks like the pulleys are for a short waterpump, do you have the stock Corvette pump on? It has it's own lenght dimension slightly longer than a short pump. As for the power steering I don't know, I looked into this set up awhile back and was told there is no direct cogs bolt up for c3's.
Old Dec 9, 2006 | 05:40 PM
onaqwst's Avatar
onaqwst
i have a vette short wp...... i understand the only difference is the pilot hole and the pulley set i have is for the sbc...... i emailed the guy and we'll see..... i might have to foget about the ps for now until i can figure it all out..... i wanted to have the 77 running this weekend since it's getting cold out....
b
Old Dec 9, 2006 | 05:48 PM
Ironcross's Avatar
Ironcross
The short water pump is for 68 and down engines, It`s not quite clear from the pictures but yours appears to be the long pump for later model engines
Old Dec 9, 2006 | 06:00 PM
mandm1200's Avatar
mandm1200
Are you sure it's a short water pump? If so, then they sent you the wrong pulley.
I believe the difference between the vette short water pump and others short styles is the vette water pump used a thicker shaft.
Old Dec 9, 2006 | 06:04 PM
77 vette's Avatar
77 vette
Dimension from block surface to hub: short pump = 5-5/8"
Dimension from block surface to hub: long pump = 6-15/16"
Dimension from block surface to hub: Corvette 71-82 = 5 16/16
Ref http://www.edelbrock.com/automotive/waterpumps.html
Old Dec 9, 2006 | 06:16 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Can't you just shim it out?
Old Dec 9, 2006 | 06:30 PM
77 vette's Avatar
77 vette
His crank pulley has a V belt grove forward of the cog pulley, I think it needs the V grove on the aft side to align with the power steering. The stock power steering and pulley mounts real close to the frame with little room to move forward. Can it bolt on reverse? Sounds kinda Bubba but maybe the alternators mount could be switched to align as well.
Old Dec 9, 2006 | 06:49 PM
onaqwst's Avatar
onaqwst
water pump is correct.... short vette.... i had to send back the wp pulley to have remilled at .75...
in his diagrams it shows the vgroove pulley outside the crank.... i thought the ps belt was inside and not outside....i might be able to mount the alt bracket different.....i couldnt find a decent alt bracket to mount on pass side either... so i have to double up on the driver side with the the alt and ps.....
i stopped after i realized this so i wouldnt throw anything since my dammit tool wasnt around........ i closed the hood and went in the house.....
b
Old Dec 9, 2006 | 07:17 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Hey B, don't worry you will get it sorted out. Sometimes walking away and going back to it in a calmer moment is the best choice. It looks like to me that either the water pump is the long version, or the pump pulley is wrong. I have the March serpentine set up, and the pump pulley rides very tight to the pump body-like a few sheets of paper tight at the closest spot at the top! These aren't the greatest pics, but maybe they will help you somehow:
Old Dec 9, 2006 | 07:30 PM
onaqwst's Avatar
onaqwst
the wp is practically touching the timing cover......
Old Dec 9, 2006 | 07:47 PM
77 vette's Avatar
77 vette
I was confused about that too. I think the length difference between the stock Corvette and regular short pump is in the casting area forward of the timing cover, the casting length/distance between the block surface and back side of pump is the same for both pumps. I think?
Old Dec 9, 2006 | 07:49 PM
7t2vette's Avatar
7t2vette
I am talking about the space between the back of the pulley and the pump body in this pic:
Look how close my pulley is to the pump in this pic:
See what I mean? I think the pulley is wrong!
Old Dec 9, 2006 | 07:53 PM
77 vette's Avatar
77 vette
onaqwst
This would be cool If you get this figured out, I really like the cog look.
Old Dec 9, 2006 | 07:58 PM
7t2vette's Avatar
7t2vette
taken from the March site:
Taken from the Edlebrock site:
short pump 1: 1969-70 350 c.i.d. Corvettes and 1955-72 light duty trucks. Has 3/4" ball/ball bearing. Dimension from block surface to hub: 5-5/8
short pump 2: Fits all 1971-82 S/B Corvettes. Comes with heavy-duty 3/4" ball/roller bearing. Dimension from block surface to hub: 5-13/16"
long pump: Fits all 1969-87 S/B Chevy or 90° V6 passenger cars and 1973-86 light duty trucks. Does not fit Corvettes. Dimension from block surface to hub: 6-15/16"
Old Dec 9, 2006 | 08:04 PM
onaqwst's Avatar
onaqwst
i wonder if i was sent the wrong wp..... i swear.... it's taking me tooo long to run this motor....
i'll take some measurements in the morning.... i think i might have to flip a few things around......
this would be soooo much easier if the motor was out...
b
Old Dec 9, 2006 | 08:09 PM
onaqwst's Avatar
onaqwst
http://www.blackmountainprecision.com/
that's the place i ordered...
b
if you see anything weird, let me know...
i dont know why the daaamn vettes have to be soo complicated with little bs changes/parts
To nothing lines up...wtf
Old Dec 9, 2006 | 08:10 PM
77 vette's Avatar
77 vette
Correct
I was trying to compare the stock Corvette water pump to the short water pump, the visial difference between the standard long to the standard short pump is obvious with a wider gap between the back of the pump to the timing chain cover, what confused me is that both standard short and stock Corvette pumps (both with different lengths) almost touch the timing cover identically.
Old Dec 9, 2006 | 08:13 PM
onaqwst's Avatar
onaqwst
so you think they sent me the wrong wp then......
b
Old Dec 9, 2006 | 08:19 PM
7t2vette's Avatar
7t2vette
b
If you have the long pump on there now, the short one will move the pulley back approx. 1 1/8".....does that seem like it would work then? Still doesn't solve your PS pump problem, or does it?
