76' Timing chain info needed.
Old Dec 11, 2006 | 02:53 PM
berger2672's Avatar
berger2672
Cruising
Default 76' Timing chain info needed.
At TDC comp. stroke & roter @ #1 term my timing dots on both the crank & cam sprocket are @ 12:00, The moter was rebult by the last person. Can someone explane why the dots are not @ 12 & 6:00.
Old Dec 11, 2006 | 03:09 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Sometimes the chain manufacturers place the dots like that. Assuming you double checked correct TDC then that's how that sprocket was made.
Old Dec 11, 2006 | 07:21 PM
Hatchetjack's Avatar
Hatchetjack
7th Gear
Rotate it one more time and they will be 12 and 6. This is because the crank turns two complete turns to the cam's one. Both ways of lining up the marks are correct ---just 12 and 6 is easier to see without a straight edge to line them up. Jack
Old Dec 11, 2006 | 10:17 PM
stingr69's Avatar
stingr69
With the dots at 6:00 on the cam and 12:00 on the crank you are on #6 TDC firing position. This is not #1 TDC Firing position as many people assume. A common misconception. I guess they tell you to assemble the engine this way because it is easy to see if you are a tooth off or not.
If you rotate the crank 360 degrees, you will have both dots at 12:00 on the crank and the cam. This will be #1 TDC Firing Position.
-Mark.
To 76' Timing chain info needed.
