Big Block valve springs
Old Sep 26, 2001 | 10:16 PM
73 LS-4's Avatar
73 LS-4
Default Big Block valve springs
While changing my valve covers I noticed that the valve springs had a dampner spring inside the outer spring, at least that's what it looked like to me. Is this stock? 73 with 049 heads.
Pat Kunz
Old Sep 26, 2001 | 10:27 PM
Tom73's Avatar
Tom73
Default Re: Big Block valve springs (73 LS-4)
Yep, they had dual springs. But, for performance, you will need to change springs as they will bind when combined with a high lift cam.
tom...
Old Sep 26, 2001 | 10:36 PM
73 LS-4's Avatar
73 LS-4
Default Re: Big Block valve springs (Tom73)
Thanks Tom, I figured that was the stock setup since the previous owner put everything back together as close to stock as possible.
:cheers:
Pat Kunz
To Big Block valve springs
