Block Hugger v Headers
Old Dec 13, 2006 | 10:12 AM
Hybrid117's Avatar
Hybrid117
Default Block Hugger v Headers
I have been looking into getting some new headers and i just got a new exhaust system installed to my stock manafolds. I was wondering the performance differnce and price differnce between (for the sake of argument) Hooker block huggers v super comp headers.
Old Dec 13, 2006 | 10:36 AM
Wrencher's Avatar
Wrencher
"Block huggers" are a performance compromise, and generally cheaper than long tubes. It just depends on your wants and needs. Personally, quality long tubes is one of the best "bang for the buck" performance bolt-ons there is besides a good cam. Also, most any competent muffler shop can marry your new pipes to the headers.
I run Super Comps on my BOSS and love 'em.
Hans
Old Dec 13, 2006 | 11:27 AM
Hybrid117's Avatar
Hybrid117
ok so i would be better off buying full headers and getting my shop to install them. How much you think that runs to get installed and whats a good price for headers
Old Dec 13, 2006 | 02:38 PM
MN80Vette's Avatar
MN80Vette
Default Block hugger caution
I installed block huggers on my '80 with a GMPP 350 HO crate engine less than 2 years ago and had to replace them this year. Block huggers (not necessarily shorties) meet half way between front and rear exhaust ports on each side and go straight down from there.
I had two problems. The first was spark plug clearance. I had to remove the header to change a couple of the spark plugs, and I burned up 3 sets of high temp spark plug wires in 2 years, even with heat sleeves on the boots. The boots cracked and arced to the header causing misfiring.
The other problem was that the header/collector/down pipe ran too close to the motor mounts and melted the polyurethane out of them.
You can save some $$ on block huggers in the short term but you will pay more with interest in the long term. I highly recommend full length ceramic headers. An exhaust shop is going to have to modify your pipes with either type of header. The $$ difference between the two jobs shouldn't be much. Find a couple of shops that bends pipes and ask them about the price difference to mount block huggers vs. full length headers.
Old Dec 13, 2006 | 03:05 PM
Little Mouse's Avatar
Little Mouse
block huggers have short tubes and no collecter length, pretty
much on them all you have is a place to bolt the exhaust pipe
to the end of the four tubes. tests show almost no gain
in block huggers over rams horns, go with an under chassis header
with 1 5/8 tubes.
Old Dec 13, 2006 | 03:32 PM
1fastC3's Avatar
1fastC3
get some stahl headers, the price is high however ive heard nothing but good things about them and performance wise they are one of the best.
-alex
To Block Hugger v Headers
