body prep before sanding
Old Dec 13, 2006 | 06:51 PM
77vettejeff's Avatar
77vettejeff
Default body prep before sanding
I started some body work following the guide from Lars. He recomends ppg dx440 for the prep solvent. I have not been able to find this in my area so I was wondering if I could use dupont 3919s. In the tech manual for the solvent it states, "Note: Do not use on unprimed plastic or fiberglass substrates due to possible static buildup, which may cause a flash fire". I do have some unpainted fiberglass that I need to clean. So, if I make sure I work in a ventilated area, is this ok? Will it damage the fiberglass or cause a problem any layers of primer I plan to put on? Thanks, -Jeff
Old Dec 13, 2006 | 07:35 PM
Durango_Boy's Avatar
Durango_Boy
You'll be better off if you stop using solvents down around the last layer of original primer. You don't want any of it getting into the fiberglass. I would suggest using the solvents to get the clear, paint, and most of the primer off the body. Block sand the rest by hand. This is important because the solvents can soak into the fiberglass, and re-appear after you have finished painting the car. Just my thoughts...others may agree or disagree.
Old Dec 13, 2006 | 08:39 PM
77vettejeff
thanks Durango, what would you think would be the best cleaner for exposed fiberglass prior to sanding? This panel is a mess!
Old Dec 13, 2006 | 10:08 PM
Durango_Boy
I use mostly water with a tiny bit of dish soap. Spray it on, and wipe it all down. Then make sure you have lots and lots of tack clothes to get the final bits of dust and lint off the surface right before you prime it.
Old Dec 13, 2006 | 10:41 PM
Scott Marzahl's Avatar
Scott Marzahl
I don't think water is a very good idea on bare glass, if this is a glass and not SMC car the glass will wick it right up and it will come out as blisters later. I would stick with an Acrylic Enamel Reducer like PPG DT860 or 870 or even lacquer thinner to wipe it down but it evaporates pretty darn fast to really clean well. Just give the reducer time to evaporate before top coating.
Old Dec 13, 2006 | 10:46 PM
Durango_Boy
Yeah I usually let it sit for a few days before I start priming, so I really didn't think about that water retention.
Oreilly has a product called Paint Prep that helps get what's left of the old primer dust off the surface, and it too evaporates VERY quickly. It should work just fine on fiberglass.
Old Dec 13, 2006 | 10:58 PM
crazywelder's Avatar
crazywelder
If you are ready for primer, you have 2 types of contamination (water soluable and oils) to remove in order to have a clean enough surface to paint over. It takes 2 types of cleaners to remove them. Use a spray glass cleaner first to remove water soluable contamination followed with the Prep Sol you mentioned to remove solvent based contamination. Wipe on and wipe off immediately. Let the car sit for a day, then blow it off and go over it lightly with a tack rag to remove dust that has settled. Solvent alone will not remove water soluable contamination.
Old Dec 13, 2006 | 11:03 PM
Vettkeeper's Avatar
Vettkeeper
http://autobody101.com/forums/forum-5.html
You might want to try this web site. Great information!!! about painting and body work.
Old Dec 14, 2006 | 06:36 PM
77vettejeff
great info, thanks!
Old Dec 14, 2006 | 06:42 PM
vettfixr's Avatar
vettfixr
I wiped mine down with a rag dampned with lacquer thinner. It evaporates almost as soon as you put it on so it doesn't leave a residue and doesn't soak into the glass.
Old Dec 14, 2006 | 08:57 PM
Durango_Boy
Man I love all that chrome, and I don't care if I've told you that before.
Old Dec 15, 2006 | 12:43 AM
enkeivette's Avatar
enkeivette
Vettfixr, I'm blind!
Old Dec 15, 2006 | 07:34 AM
vettfixr's Avatar
vettfixr
Thanks guys. Actually, its an old picture. I have to take some new ones with the Billet Specialties valve covers and air cleaner. I have a few but they suck. I'm better at turning wrenches than pressing a shutter.
Old Dec 15, 2006 | 08:50 AM
Durango_Boy
We know that for sure now, because no one presses a shutter anymore...it's a button that tells the camera to take a digital picture. I still have some old film cameras, but it's almost too much of a hassle when I can get just as good of shots from my digital cameras.
To body prep before sanding
