Header Removal
Old Dec 14, 2006 | 12:35 PM
JoeRags's Avatar
JoeRags
Default Header Removal
For the life of me, I cant get my driver side header off Any time they have come off/on, either the body was off the car, or the whole engine came out. Alternator is off, valve cover off, spark plugs out, and steering box unbolted (not removed).
My flanges are warped and I want to re-surface them before I put on the final set of Percey gaskets with lock wired bolts. Hopefully this will eliminate all future header leaks.
They are full length Hooker's, small block, 4-spd.
Hints/tips/tricks anyone?
Old Dec 14, 2006 | 12:38 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Are you trying to get them out from the bottom? Don't go through the top - that sounds like what you are trying to do.
Old Dec 14, 2006 | 01:15 PM
JoeRags's Avatar
JoeRags
Tried both... and if removing from the bottom, how do I get past the dip-stick tube?
I already broke off one dip-stick tube this year and had one hell of a time pulling the broken off end out of the block...
I DONT want that to happen again. I'm guessing I'll have to remove the clutch Z-bar as well to remove from the bottom, no?
Old Dec 14, 2006 | 01:21 PM
lars's Avatar
lars
Yes, you have to pull the Z-Bar, the oil filter, and you have to pull the dipstick tube out. The header comes out the bottom, but you need the car on a lift or with a LOT of ground clearance.
Old Dec 14, 2006 | 01:32 PM
JoeRags's Avatar
JoeRags
Thanks Lars... car is on the lift.
Whats the easiest way to pull the dipstick tube without damaging it? Am I going to have to replace it anyway?
Old Dec 14, 2006 | 01:43 PM
BB72's Avatar
BB72
Default Lars is right but
Filter can stay in...did it many times on my 81. LOTS of ground clearance needed. What a bitch of a job though. You pretty much have to be a contortionist to work under these things with no hoist. As far as the tube, get a screwdriver or chisel punch and from the underside hit the lip right at the block punching it up.
Old Dec 14, 2006 | 02:20 PM
halfmoontrail's Avatar
halfmoontrail
Noooooo...likely to end in tears. Grab it with visegrips, just tight enough to hold, lightly hit the visegrips upward.
Steve
Old Dec 14, 2006 | 02:43 PM
JoeRags's Avatar
JoeRags
Steve
Yea, I'll try that first...
Old Dec 14, 2006 | 05:51 PM
lars's Avatar
lars
You can stick a phillips screwdriver or a straight punch down into the tube - something that just barely goes into the tube. You can then grab it with visegrips without flatteing the tube. Wiggle and pull. Before you put your headers back on, you can slit the header flange for the tube - much easier install that way.
Old Dec 14, 2006 | 08:55 PM
JoeRags's Avatar
JoeRags
Thats a great idea... didnt even think of that. Thanks Lars.
Old Dec 14, 2006 | 08:58 PM
Kalway's Avatar
Kalway
Your dipstick tube is in the way? Mine is on the passenger side... I just kinda bent it so it's out of the way.
Did you take the spark plugs out before you attempted to take the headers off? That gave me one hell of a time when I did mine.
Old Dec 14, 2006 | 11:06 PM
JoeRags's Avatar
JoeRags
Already broke one dipstick tube because it got bent during a header install.... I'll never bend it again after going through that fiasco.
To Header Removal
