CRATE 502/502: WHICH SPARKPLUGS?
Old Sep 27, 2001 | 10:30 AM
MELVIN's Avatar
MELVIN
Default CRATE 502/502: WHICH SPARKPLUGS?
INSTRUCTION SHEET SAYS #4 DELCO RAPID FIRES (LARGE GEAD), WEBSITE SAYS R43XLS (LARGE HEAD), PARTS STORE SAY GO WITH 454 PLUGS (WHICH HAVE THE SMALL HEAD) WHILE THEY WILL ALL FIT, SOME HAVE LARGE OR SMALL HEAD, SOME HAVE DIFFERENT REACH
I HAVE THE R43XLS. GOOD TO GO?
Old Sep 27, 2001 | 11:13 AM
zwede's Avatar
zwede
Default Re: CRATE 502/502: WHICH SPARKPLUGS? (MELVIN)
Melvin,
Don't know what you mean by 'large head'? There are a few factors determining spark plugs:
Gasket or taper seat. The aluminum heads you have take gaskets.
Long or short reach. Aluminum heads use long reach.
Projected tip or regular tip. With flat top pistons, use projected for better burn.
Heat range. I have found an aluminum head big-block likes rather cold plugs.
I'm running AC Delco FR2LS, which is gasket seat, long reach, projected tip in heat range 2 (cold). My heads are the edelbrock aluminums, basically identical to your 502/502 heads.
Not sure exactly what the difference is to the R43XLS, but if they are gasket, long reach and projected tip they should work fine. Heat range (3) is good.
Old Sep 27, 2001 | 11:21 AM
MELVIN's Avatar
MELVIN
Default Re: CRATE 502/502: WHICH SPARKPLUGS? (zwede)
By large and small head spark plugs, I meant the size socket that is used. The large head takes a 7/8" socket, and Im not sure which size the small does. I wasnt sure of the correct terminology.
Im thinking the R43XLS are correct ones?
Old Sep 27, 2001 | 11:23 AM
Steve439's Avatar
Steve439
Yeah, they should be fine, although I find 'em a little cold for the street.
I'm running R44XLS on my GM heads and they look great.
Old Sep 27, 2001 | 07:00 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
The engine comes stock with ACDelco #4, part number 25164642. Recommended gap is .035"
Old Sep 28, 2001 | 08:45 AM
MassVette's Avatar
MassVette
Melvin,
I kept fouling out #1 & #3 plug with the rapid fire 4's, so I switched to R43XLS----runs fine ........
:chevy
Old May 23, 2016 | 02:51 PM
Richard G Engel's Avatar
Richard G Engel
1st Gear
Originally Posted by MassVette
Melvin,
I doubt that the 43 will work long. The rapid fire 4 is a HOTTER plug and I am fouling badly on them I have gone to a step hotter which is R45XLS
Any new shiny plug is going to run fine for a while. Its after they get fouled a little and have a harder time cleaning up. Seems to me the hot ticket is to order Rapid Fire 5s
Old May 23, 2016 | 03:25 PM
zwede's Avatar
zwede
Zombie alert! (you resurrected a 15 year old thread)
But welcome to the forum.
To CRATE 502/502: WHICH SPARKPLUGS?
