What is a L81 ?
Old Dec 15, 2006 | 04:01 PM
Rich N.'s Avatar
Rich N.
Default What is a L81 ?
My '81 has a ZZ4, but the original motor is shrink wrapped laying in the garrage. I'm almost ready to take a wrench to it. isn't the L81 supposed to be a one of a kind ? I have been searching this forum and other sites to get the specs for what's inside the 2 bolt block. I have the usual hp, torque ratings, etc, but no real specs. I can't seem to locate the tech data anywhere. I have read that "maybe" the L81s have forged pistons and performance cams. so "maybe", what kind of heads and cranks do they have ? are they really different, or just a L48with computerized dist & carb ? don't want to unwrap early. just idle curiosity.
Merry Christmas ! Rich
Old Dec 15, 2006 | 04:04 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The L81 is the standard engine for the '81 Vette, 350 CI, 190 HP.
Old Dec 15, 2006 | 09:35 PM
Rich N.'s Avatar
Rich N.
OK Judd. I see you don't know either. is there anyone out there who has popped open a L81 ? I don't know anyone who has. if the motor bottom is as good as the psuedo data, then maybe some head work, a good intake, and true duals may produce a real performer for very little money. is it a diamond in the rough, or just another compromise coming out of the oil scared 70s ?
Old Dec 15, 2006 | 09:57 PM
Big2Bird's Avatar
Big2Bird
I pulled the heads and pan off my L-81. 2 bolt main, 74 cc heads, nothing special. Boght a universal crate engine from summit for 1350 delivered. 4 bolt main. Can't rebuild a 350 for that. Nothing beats new with a GM Warranty. Runs great, has 260 HP, and passed smog EASY.
Glensgages's Avatar
Glensgages
http://forums.corvetteforum.com/show....php?t=1572890
Old Dec 15, 2006 | 10:00 PM
BB72's Avatar
BB72
Default I had an 81
I rebuilt the motor myself, it was a correct #'s motor so I know the crank was cast, the block was 2 bolt and the pistons looked cast. I believe the heads were 624 casting, alright but nothing you would want to port.Nothing special about the motor. It was the first year for computer controls. Does that answer your question? Yes you could easily get 300hp out of it reliably.
Old Dec 15, 2006 | 10:13 PM
Kalway's Avatar
Kalway
It has L-82 valve covers.
Old Dec 16, 2006 | 12:01 AM
Rich N.'s Avatar
Rich N.
so no gem waiting to be discovered. I'll leave the engine wrapped for the next owner. thanks for the first hand info. that's why this forum is the best on the internet.
Old Dec 16, 2006 | 12:35 AM
RIJVETTES's Avatar
RIJVETTES
I don't want to hijack the thread, but it may have run its course anyway. So Big2Bird, I'm considering the new crate engine route for my 80. Did you purchase a short block or long block? Not a turn key for that price. What old vs new parts did you add? I assume your at 8.5:1 compression. How does the throttle feel, compared to the stock engine? I also have to pass the visual and sniff smog police cause I'm in California- but I want the most power possible. If you passsed smog easily, that suggests the new heads and a cam might be a good addition to that inexpensive block.. Thanks for your thoughts. Jim
Old Dec 16, 2006 | 12:37 AM
Jud Chapin's Avatar
Jud Chapin
Sorry, I thought one of your questions was "isn't the L81 supposed to be a one of a kind?". Didn't see how it could be when it was the only engine made for the 40,606 '81's Vettes produced. Just trying to help.
Old Dec 16, 2006 | 01:13 AM
cv67's Avatar
cv67
St. Jude Donor '05
You asked, he answered.
Old Dec 16, 2006 | 01:24 AM
Big2Bird's Avatar
Big2Bird
Jim, Go to Summit Racing, and check out GM#10067353. It is a long block, and GM warranty for 3yr,50,000mile if installed in a 68-85 GM car.All I did was add an Edelbrock intake, and stock everything else. Runs like a new car, cause it is. The smog guy said he has never seen an old car with such low emissions. He thinks I could have upped the cam and passed. If your ever in Anaheim, e-mail me. Jeff
Old Dec 16, 2006 | 02:04 AM
RIJVETTES's Avatar
RIJVETTES
Thanks for the reply Jeff. I'm seriously considering the new long block instead of the cost and no warranty of a rebuild. But I gotta believe that Edelbrock aluminum heads- the 65 or 70 cc, and a slightly more aggressive cam would punch up the hp and tq significantly and still pass CA smog. Jim
Old Dec 16, 2006 | 02:22 AM
cv67's Avatar
cv67
St. Jude Donor '05
We'll find out soon. Doing a 10:1 350 with the 64cc Edelbrock performers and Lunati 256 Voodoo for a friends IROC. Dropping it in this weekend. DId a little headwork/intake porting, has E.O. headers, should be interesting
To What is a L81 ?
