Jacking points on shark?
Old Sep 27, 2001 | 11:30 AM
Racer78's Avatar
Racer78
Default Jacking points on shark?
can you jack under the engine x meber in front? Under the diff or spring attactment point in rear?
Keith
Old Sep 27, 2001 | 11:37 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Jacking points on shark? (Racer78)
I do it all the time, you will dent up the front cross member tho.
Do it from the side on the frame rails if you can...
Old Sep 27, 2001 | 12:02 PM
1LE's Avatar
1LE
Yes you can.
Old Sep 27, 2001 | 01:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
At the rear, jack the differential. It's risky jacking from beneath the spring.
Old Sep 27, 2001 | 01:37 PM
Racer78's Avatar
Racer78
Default Re: Jacking points on shark? (Easy Mike)
Mike,
Thanks, i figured it out, can't get to spring anyway exhaust in the way.
After i had the front up, i wenr under middle and jacket on cross member ahead of diff, not much weight with front up on stands at frmae corners, went right up.
Man the diff lube check plug is in a nice place
Old Sep 27, 2001 | 02:19 PM
terryrudy's Avatar
terryrudy
BTW, here is a diagram of jacking points: http://users.erols.com/jerryp58/corvette/jackpts.jpg
-terry
Old Sep 27, 2001 | 03:43 PM
Racer78's Avatar
Racer78
Default Re: Jacking points on shark? (terryrudy)
thanks Terry
To Jacking points on shark?
