Brake light on 76
Old Sep 27, 2001 | 11:51 AM
MikeT's Avatar
MikeT
Default Brake light on 76
My right rear brake light works but just barely shines. Left one is bright and works great! I checked the ground wiring (only found one on the harness) and it was grounded well. Changed bulbs and cleaned posts but that didn't make any improvement. Any suggestions or am I missing something?
Old Sep 27, 2001 | 02:05 PM
MikeC's Avatar
MikeC
Default Re: Brake light on 76 (MikeT)
Mike,
Can't really help, other than if your ground was bad the light would go out not go dim. I would think there might be sort of resistance in the line that is dropping the voltage of the light.
The only thing else I can do is bump this to the top and hope someone else can help you better
Old Sep 27, 2001 | 03:02 PM
john's '81 mouse's Avatar
john's '81 mouse
Suggest you double check grounds, look for ground in rear under bumper by tail lights. Sounds like a bad / barely working ground to me.
To Brake light on 76
