engine stop leak
Old Dec 17, 2006 | 10:57 AM
soccer794's Avatar
soccer794
Default engine stop leak
Anyone used any of those stop engine leak additives? Did it work at all? Pretty sure I have some leaking past the seals and have a leak coming from somewhere I can't seem to find wondering if this would help at all or not?
Old Dec 17, 2006 | 05:09 PM
marshrat99's Avatar
marshrat99
IMO these additives are snake oil. Don't use them. You'll be much better off using brake cleaner to get rid of the accumulated junk and find out exactly where the leaks are coming from and then replacing the culprit seals and gaskets. Let us know where you find the leaks and then we'll help you out in the easiest way of replacing the gaskets or seals.
Old Dec 17, 2006 | 05:33 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
yep. Seal Swelling additives are not what you want. Why put a band aid on a cut that needs stitches? Why not fix the oil leak properly?
Old Dec 17, 2006 | 05:54 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Actually, I believe that some of the sealer additives of today are excellent. Lucas is a brand that comes to mind. I have a '91 Mark VII and about 2 years or so ago the PS pump started leaking. While I felt the same way then as marshrat feels now, a friend suggested Lucas PS stop leak additive. I added a bottle and to my amazement the leak stopped immediately and hasn't leaked since. I have heard others tell me that the block sealers work equally well including those intended to seal head gaskets. I work p/t at an auto parts store and I can tell you that we sell a ton of this stuff. I'm not saying that all of it is good, but I think the better names like Lucas are not going to sell products that don't work. Just my 2 cents.
Old Dec 17, 2006 | 08:24 PM
petronix's Avatar
petronix
Another 2 cents.... I replaced the original power steering hoses on my 72, which were badly cracked and running on borrowed time. The original power steering ram was leaking a bit at the time. I refilled the ps pump with some type of leak stopper fluid (don't remember what kind, but it was a name brand). I haven't had to add fluid in over 2 years ~5000 miles, including a trip from NJ to FL. Leak stopped.
Old Dec 17, 2006 | 09:32 PM
w1ctc's Avatar
w1ctc
Bars leak just prevented a major upheaval at my house. The fully decorated Christmas tree was in a stand that started to leak all over the carpet. Put some of that powder in and saved the day.
Old Dec 17, 2006 | 09:34 PM
SmokinBBC's Avatar
SmokinBBC
Old Dec 18, 2006 | 01:13 PM
Bill Z's Avatar
Bill Z
For what it is worth. I aggree.
Unless you are selling the car. Then use the stuff and give the problem to some one else.
Old Dec 18, 2006 | 01:19 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Note to self: Do not buy from Bill Z.
Old Dec 18, 2006 | 01:34 PM
Hvymtlc5's Avatar
Hvymtlc5
Does Lucas make an oil supplement designed to "help" stop leaks? My Vette doesn't leak, but my Neon's rear main is starting to go and is making a mess of the driveway.
Old Dec 18, 2006 | 04:09 PM
Bill Z's Avatar
Bill Z
Anyone want to buy a Corvette? I have a perfect one to sell. No leaks!!! ;~)
Old Dec 18, 2006 | 04:20 PM
Big2Bird's Avatar
Big2Bird
I have found the best stop leak ever invented. It is called a gasket.
Old Dec 18, 2006 | 05:22 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Gotta love this forum
To engine stop leak
