Exhaust Studs
Old Dec 17, 2006 | 12:51 PM
bmankin's Avatar
bmankin
Default Exhaust Studs
Is the exhaust stud on a C3 passenger side exhaust manifold longer than a standard GM stud?
Old Dec 17, 2006 | 01:20 PM
TimAT's Avatar
TimAT
GM uses a heat riser on the passenger side- the studs are longer to compensate. Usually 2" or so.
Old Dec 17, 2006 | 02:18 PM
bmankin's Avatar
bmankin
I knew they were longer than the drivers side but are they longer than the standard studs that you buy in a kit at a parts house? I barely have enough thread to catch them. I didn't know if I needed to back them out a little or seek a longer stud. Thanks
Old Dec 17, 2006 | 04:47 PM
marshrat99's Avatar
marshrat99
Part houses have seveal different sizes that you can buy. Just measure your current ones and then go buy the next longer size. You can get some with brass nuts that won't corrode and much, much easier to later remove.
Old Dec 17, 2006 | 05:01 PM
Ironcross's Avatar
Ironcross
Passenger side is 3 1/4 long 3/8 USS both ends. Use brass nuts too.
Old Dec 17, 2006 | 07:52 PM
bmankin's Avatar
bmankin
Thanks Dude, That's exactly what I needed to know.
To Exhaust Studs
