Starter problems
Old Dec 18, 2006 | 04:51 PM
jhuff's Avatar
jhuff
Default Starter problems
I have issues with the car starting when the motor is hot. Does anyone know of a good replacement starter? Aparently this is a major design flaw in the gm starter.
Old Dec 18, 2006 | 05:05 PM
Gary's 1977 Vette's Avatar
Gary's 1977 Vette
Default Starter
Any good rebuilt starter will work fine. Just put a heat shield on it and this will make all the difference in the world.
Old Dec 18, 2006 | 05:08 PM
Gordonm's Avatar
Gordonm
Get a GM mini starter and be done with it. Smaller and lighter and I have never had any starter issues since I installed it 5 years ago. It is used on many GM vehicles and you can find one new or rebuilt.
Old Dec 18, 2006 | 05:42 PM
BLUSHRK's Avatar
BLUSHRK
I used a new full-size starter, heat wrap, AND a shield and it still got hot. Don't waste money on anything. Get a mini-starter and be done with it. My exhaust runs right by the starter and it's fine. The mini's are the way to go.
Old Dec 18, 2006 | 06:09 PM
jhuff's Avatar
jhuff
any particular brand better than others for the mini starter? and what is a good place to get them from?
Old Dec 18, 2006 | 06:42 PM
Ironcross's Avatar
Ironcross
A absolute waste of money!
Old Dec 18, 2006 | 08:21 PM
SHOWME's Avatar
SHOWME
I have to agree to go with the mini starter. I had all the same problems and used a heat shield and wraps ect.Alot of the problems come from the wires gettin cooked from being too close to the exhaust.
The mini has more power and alot more room for routing wires away from the heat.It never drags,skips, or acts weak.I also liked the weight savings.(I could hold it up and bolt it in with no fatigue or fight for space.It's been on for over two years so far and has always worked flawless! (It even turns it over with a weak battery)
Old Dec 18, 2006 | 08:45 PM
jhuff's Avatar
jhuff
wow. thanks for the completely useless advice Ironcross.
Everyone else thanks a lot. I am goin to go down to the local speed shop this weekend and see if they can recommend a good mini-starter.
To Starter problems
